Cleaning the firewall after volt regulator/ecm failure #1861495
07/01/15 08:35 PM
07/01/15 08:35 PM
Central Texas
b_body_fan Offline OP
Central Texas
Does anyone have any tips or suggestions for cleaning the melted stabilizing gel from the firewall after a voltage regulator/ecm failure? Is there a product that will help clean it up? What about using a heat gun?
Re: Cleaning the firewall after volt regulator/ecm failure [Re: b_body_fan] #1861515
07/01/15 08:59 PM
07/01/15 08:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Be careful with the heat. You can burn the paint off too.
- Stu Harmon
Re: Cleaning the firewall after volt regulator/ecm failure [Re: b_body_fan] #1861715
07/02/15 12:36 AM
07/02/15 12:36 AM
Posting from 1893 in NW FL
TheBlueBeast Offline
No idea on cleaning up that mess.
It is part of the charm of owning a Mopar.
Re: Cleaning the firewall after volt regulator/ecm failure [Re: b_body_fan] #1861828
07/02/15 06:50 AM
07/02/15 06:50 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
I had that happen, Goo-Off, some wd40 and lots of elbow grease
Re: Cleaning the firewall after volt regulator/ecm failure [Re: solarguy] #1861931
07/02/15 12:33 PM
07/02/15 12:33 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I thought it was called "Goof-off"? No wait! That is what I am doing now!
However, I agree with your suggestion. A gold star for you!
