1970 440 six pack outboard carb question... #1859055
06/28/15 06:55 PM
06/28/15 06:55 PM
La Habra, CA
70440SIXPK Offline OP
La Habra, CA
Hi guys, I was wondering if these air bleeds on the outboard 440 six pack butterflies were original? I have three outboard carbs, and all have the same holes in the same locations??? Thanks!
1970 Challenger
Factory V Code
Re: 1970 440 six pack outboard carb question... [Re: 70440SIXPK] #1859086
06/28/15 07:56 PM
06/28/15 07:56 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
I believe so.
I think it was to work with the idle circuit mixture. they are almost right above where the bleed needles come out.
Also -
I would imagine that you would want the butterflies completely shut at idle and without the holes you would not have any bleed air for the idle circuit.
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: 1970 440 six pack outboard carb question... [Re: 72ls5fla] #1859151
06/28/15 09:26 PM
06/28/15 09:26 PM
La Habra, CA
La Habra, CA
Yeah, I thought that they looked a little too centered as far as location ... I don't see anyone taking that much time to measure the hole locations so perfect..
1970 Challenger
Factory V Code
Re: 1970 440 six pack outboard carb question... [Re: 70440SIXPK] #1859363
06/29/15 12:13 AM
06/29/15 12:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
They're all in the same place.
Re: 1970 440 six pack outboard carb question... [Re: 62maxwgn] #1859460
06/29/15 02:34 AM
06/29/15 02:34 AM
La Habra, CA
La Habra, CA
Awesome! Thanks for the info!
1970 Challenger
Factory V Code
