NE1 installed a FAST EZ-EFI 2.0 in an A-body? #1856376
06/25/15 01:58 AM
06/25/15 01:58 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I purchased a FAST EZ-EFI 2.0 for my 1970 Dart, but now that it's here I'm struggling with how to do a sanitary installation in the tight confines of the engine compartment. Even with a small block there is virtually no real estate available on the firewall to route the cable. (It requires a 2" diameter hole) and if I mount the ECU under the hood there is a snake's nest of wiring to deal with. Just wondering if anyone has any photos of an A-body, or even a B or E body, installation that might give me some ideas.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1857451
06/26/15 03:40 PM
06/26/15 03:40 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I have the EZ 1.0 on my Road Runner, so I'm not sure if the wiring is the same. I installed the ECU under the battery tray, and removed all the GM wire looming and wrapped the wiring myself. No "snake's nest" of wiring at all. There isn't much wiring with the system. Most people are surprised when I tell them it is fuel injected! Hopefully the pic attached.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1857456
06/26/15 03:45 PM
06/26/15 03:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One place to think about is in the wheel well forward of the tire. Hidden, plenty of room and cooler than the engine compartment, but it is wetter and debris might hit the unit unless you fab up a shield of some sort.
Don't be the exception.
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1857467
06/26/15 04:11 PM
06/26/15 04:11 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
A few more pics of my install.
1999 Dakota R/T
2000 Viper GTS
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: D149] #1857469
06/26/15 04:12 PM
06/26/15 04:12 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
More pics
1999 Dakota R/T
2000 Viper GTS
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: D149] #1857471
06/26/15 04:13 PM
06/26/15 04:13 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
One more
1999 Dakota R/T
2000 Viper GTS
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: D149] #1858528
06/27/15 11:05 PM
06/27/15 11:05 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks for the photos! They do help. I've got my battery mounted in the trunk, but my first thought had been to put the battery tray back in and use the top side to mount the ECU and hide the wiring underneath. I'm really leaning that way now that I see what you've done.
One other question, how long is the cable that you have for connecting the hand held programmer to the ECU? My kit only give me maybe a couple of feet of length. I think they left out an extension cable that is supposed to be included. Just wondering what you got with your setup.
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1858796
06/28/15 12:13 PM
06/28/15 12:13 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I'm not sure what the exact length is, but it reaches from the ECU under the battery tray into the interior through the speedo cable hole and I attach the hand held under the dash. I would guess it is 5 or 6 feet long.
If you need any more pictures, just let me know.
1999 Dakota R/T
2000 Viper GTS
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1858835
06/28/15 01:08 PM
06/28/15 01:08 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
My kit is definitely missing the extended cable to the hand held unit. :~(
I'll have to get in touch with Summit where I bought it and see if they can help me out. Did you run the cable to the interior permanently with a hole and grommet thru the firewall? Thanks again for the photos, I'm about 99% sure I'm either going use the original battery tray, or make a custom mounting tray to go in the same location.
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: MadMatt] #1858926
06/28/15 03:21 PM
06/28/15 03:21 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I didn't drill a new hole in my firewall. I went through the speedo cable hole.
1999 Dakota R/T
2000 Viper GTS
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: D149] #1859745
06/29/15 04:32 PM
06/29/15 04:32 PM
K
Kiddart Offline
Kiddart  Offline
K
I have the 1.0 on my dart. just installed it and so far I really like it. I may have a few problems down the road when I start to Taylor the tunes due to my cam shaft and lack of vacuum, we will see. but it was a very easy install and the car fired up relatively easy. I only had to bring the idle up a half turn and she ran just fine. and be patient with the system. its very different than a carb. go to the fast website and join the chat forum, everything and anything you need is at your finger tips. I cant wait to really log some hours on my car.
Their is also a very large member community here that is a vault of knowledge with EFI. I will purchase the 2.0 soon and take the 1.0 and put on another car. there is an update coming for the 1.0 that give a lot more tune-ability like the 2.0.
so far the old iron likes the updates.
Good Luck and enjoy the added reliability
Thank you
Kiddart
Re: NE1 installed a FAST EZ-EFI 2.0 in an A-body? [Re: Kiddart] #1860072
06/29/15 11:25 PM
06/29/15 11:25 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks for the suggestion about the chat forum at FAST. Heading over there now to join.
