for the millionth time..carb choice.. #1855507
06/23/15 09:25 PM
06/23/15 09:25 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
512 Stroker build..Indy EZ-1 heads..Edelbrock low deck crossram intake..estimated 600 horse with 600 ft lbs of torque..10.5 to 1 compression..hyd roller cam. automatic trans...street / strip motor..
What carbs? brand and cfm??
Help.!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855522
06/23/15 09:52 PM
06/23/15 09:52 PM
Washington
madscientist Offline
Washington
2 750 DP's minimum. I would call BLP, Dale Cubic or Braswell.
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855588
06/23/15 11:17 PM
06/23/15 11:17 PM
AndyF Offline
AndyF  Offline
Good luck is all I can say.
If you actually want a combination that runs hard and is easy to work on then sell the cross ram and buy an Indy 400 intake. A brand new 850 DP carb should work just fine on that combo and will be easy to tune.
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855782
06/24/15 09:49 AM
06/24/15 09:49 AM
gregsdart Offline
gregsdart  Offline
I have a pair of used Endurashine 500cfm carbs if you are interested in some bling. Your pm box is full, by the way.
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855829
06/24/15 12:22 PM
06/24/15 12:22 PM
Mark Whitener Offline
Check out the weekend warrior carbs from BLP, billet body carbs. May need to make a few adjustments to use as 2 carbs, but a good choice. A pair of 650's is what I would go with. Let me know if you are interested.
http://blp.com/78-featuring/264-all-new-bx-4-billet-weekend-warrior
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855915
06/24/15 02:16 PM
06/24/15 02:16 PM
One of the first motors I built for a customer a long time ago was a 383 with the stock early 4 bolt valve cover heads(little valves and all down) and a early production Eddy two piece STR (Street Tunnel Ram maybe)crossram intake manifold, it had either 600 or 650 Holley D.P. on it, CRS shruggy It ran well above 3000 RPM but most of that was due to the cam and a stone stock low stall OEM conveter down I've since owned and race a bunch of BB with M.W. heads and crossrams with dual carbs, all the way from stock to using dual Holley 850 D.P., as already suggested get a set of Holley 650 or 750 D.P. or a set of the Hi Po(non smog carbs) Eddy or Carter type (625 or 750 CFM)carbs will work good also up twocents Mopar BB like a lot of air and fuel is what I have seen in testing and racing work
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1855925
06/24/15 02:34 PM
06/24/15 02:34 PM
AndyF Offline
AndyF  Offline
The cross ram intakes just aren't that good when it is all said an done. If this is just a cruiser and you like the looks of the cross ram then put a pair of Edelbrock 500's on there. At least those carbs will allow you to start the engine without too much drama and you'll get half way decent performance. At the minimum you should install a dual channel wideband. Good luck actually trying to tune that thing though. You'll get lost really quickly if you try to cross jet it or popsicle stick the intake or anything else. There is a reason they don't make those intake manifolds anymore!
Re: for the millionth time..carb choice.. [Re: 72N96RR] #1856150
06/24/15 08:45 PM
06/24/15 08:45 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
While the crossroad looks cool on our '63's I went with a Holly Street Dominator and an 850 Demon. Works great and has better drivability than the 750 3310 Holley.
'63 Dodge 330
11.19 @ 121 mph
Re: for the millionth time..carb choice.. [Re: GY3] #1856249
06/24/15 11:03 PM
06/24/15 11:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree the crossram looks awesome under the hood of a 62 to 64 Mopar of the Max Wedge era. I did not use one at first because of the exspense and I am very happy with the Indy dual plane and 850 Holley DP I use. As Andy said it is very simple to tune and I like my hotrod easy to work on. If you ever decide against the crossram the Indy dual plane works very nice on my 493 street/strip car and have great driveability at all rpm levels. Good luck with the cool crossram if you do go that way. I can say my brother uses the Mod Man intake on his 64 with a 511 and he uses two Eddy 650's I believe. He has it running very good with the two Eddy's but it is a race car and not street driven. One thing I like about the Eddy and Carter carbs are you can do alot of tunning with the metering rods and you dont spill fuel when jetting them. grin Ron
