I need a picture of under a 69 barracuda #1852078
06/18/15 08:37 PM
06/18/15 08:37 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Anyone have a picture of the driver's side underfloor of a 69 barracuda or similar. I'm having a problem running my ebrake cable and brake line. Can't figure out exactly where the run.
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852330
06/19/15 01:53 AM
06/19/15 01:53 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This is 69 Barracuda.
A. Front cable anchor
B. Cable equalizer
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852333
06/19/15 01:58 AM
06/19/15 01:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
C. Rear cable clips.
D. Short cable to L wheel.
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852336
06/19/15 02:04 AM
06/19/15 02:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
E. Long rear cable to R wheel
F. Long rear cable again.
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852338
06/19/15 02:07 AM
06/19/15 02:07 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
G. Long cable clamp.
H. Clamp again
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852341
06/19/15 02:11 AM
06/19/15 02:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I. Long cable on axle.
J. Long cable to R wheel. The end of parking brake photos.
If you still need brake pipe photos, that's a dozen more due to all the clips involved. It takes a lot of photos from close up, because I can only get the car up about 2 ft.
Holler if you want brake pipe photos.
Re: I need a picture of under a 69 barracuda [Re: kentj340] #1852420
06/19/15 10:31 AM
06/19/15 10:31 AM
Shelby, Ohio
2
Shelby, Ohio
perfect pictures. I really appreciate the good pics and info. thanks
Re: I need a picture of under a 69 barracuda [Re: 2abodymcodes] #1852529
06/19/15 02:38 PM
06/19/15 02:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
X2 I'll use these when I put mine back together. On old race cars all that stuff is trashed.
Re: I need a picture of under a 69 barracuda [Re: cudaman1969] #1852927
06/20/15 12:00 AM
06/20/15 12:00 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Should be in the Tech Archives! bow
JB Rhinehart, Realist
A-Body's RULE!
Re: I need a picture of under a 69 barracuda [Re: Rhinodart] #1853521
06/20/15 10:30 PM
06/20/15 10:30 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's one more photo that should have been included between E and F. The upper cable is the long rear P brake cable going to the R wheel. Below and to the right is the back end of the front-to-rear brake line. The flex brake hose and the brake line join in the bracket hole.
Note the bracket has a notch to catch the P brake cable.
