Re: I need a picture of under a 69 barracuda
[Re: 2abodymcodes]
#1852330
06/19/15 01:53 AM
06/19/15 01:53 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is 69 Barracuda.
A. Front cable anchor B. Cable equalizer
[Re: 2abodymcodes]
#1852336
06/19/15 02:04 AM
06/19/15 02:04 AM
kentj340
Cut and Shoot, TX
E. Long rear cable to R wheel F. Long rear cable again.
[Re: 2abodymcodes]
#1852341
06/19/15 02:11 AM
06/19/15 02:11 AM
kentj340
Cut and Shoot, TX
I. Long cable on axle. J. Long cable to R wheel. The end of parking brake photos.
If you still need brake pipe photos, that's a dozen more due to all the clips involved. It takes a lot of photos from close up, because I can only get the car up about 2 ft.
Holler if you want brake pipe photos.
[Re: 2abodymcodes]
#1852529
06/19/15 02:38 PM
06/19/15 02:38 PM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
perfect pictures. I really appreciate the good pics and info. thanks X2 I'll use these when I put mine back together. On old race cars all that stuff is trashed.
[Re: Rhinodart]
#1853521
06/20/15 10:30 PM
06/20/15 10:30 PM
kentj340
Cut and Shoot, TX
Here's one more photo that should have been included between E and F. The upper cable is the long rear P brake cable going to the R wheel. Below and to the right is the back end of the front-to-rear brake line. The flex brake hose and the brake line join in the bracket hole.
Note the bracket has a notch to catch the P brake cable.
