? about Fiberglass fender head light buckets? #1850135
06/16/15 12:25 AM
06/16/15 12:25 AM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
The guy that painted my duster traded me a set of fiberglass front fenders for my 73/72 dusters.Well the fenders did not come with head light buckets, So i bought a set through unlimited fiberglass. I kind of understand how they mount but would like to get some tips and advice from people that already have installed a set.
Also i want to install my head lights but i am wondering how you keep the spring for the metal head light bucket from ripping through the fiberglass bucket?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1850488
06/16/15 02:32 PM
06/16/15 02:32 PM
mopar65 Offline OP
mopar65  Offline OP
Man I figured somebony would have some advice on installing them
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1850584
06/16/15 05:26 PM
06/16/15 05:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Sounds like it might be easier to use stock buckets if you want to use real headlights.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1850635
06/16/15 07:48 PM
06/16/15 07:48 PM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
I would call the manufacturer and ask. But would probably install a metal grommet to keep it from wearing. I installed a one piece f/g front and welded in the buckets and mounts. A pain doing.
Re: ? about Fiberglass fender head light buckets? [Re: BIGBLOCK_KAT] #1850640
06/16/15 07:53 PM
06/16/15 07:53 PM
st. Louis Mo.
dartphil Offline
dartphil  Offline
st. Louis Mo.
I have a 72 duster with glass fenders and real headlights, I will have to see how they did it and try to post you a pic.
Re: ? about Fiberglass fender head light buckets? [Re: dartphil] #1850863
06/17/15 01:11 AM
06/17/15 01:11 AM
mopar65 Offline OP
mopar65  Offline OP
Sir that would be awesome. up This is my first time messing with fiberglass fenders so sorry for the dumb questions.
I was thinking about if i couldn't get the fiberglass buckets to work, to find a junk set of fenders and cut the head light bucket out of them and use them.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851229
06/17/15 06:27 PM
06/17/15 06:27 PM
st. Louis Mo.
dartphil Offline
dartphil  Offline
st. Louis Mo.
I took a couple pics but cannot figure out how to post them here. Looks like they cut holes on the fenders behind the lights and just bolted the metal buckets to the fender, I see no way of adjusting them,I don't have my lights working,but am planning to get them hooked up and make this a pro street/ drag car. Guess i'll have to figure our a better way of mounting them myself if I want any kind of adjustments.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851318
06/17/15 09:05 PM
06/17/15 09:05 PM
mopar65 Offline OP
mopar65  Offline OP
Hey thanks for the info.on my fenders they came with no head lite buckets at all. wear the head light would bolt too on mine is just open space.Thats why i had to buy some fiberglass buckets. also if i give you my email address could you send me the pics? if a little bit i will take a pic of the buckets i am talking about. but maybe we are talking about the same thing.lol
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851357
06/17/15 10:01 PM
06/17/15 10:01 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Just did it on a set of 1968 Dart fenders. The first thing you have to do is cut the nose of steel fenders about 1/2 back removing the flange. Then cut the outer skin of the fender saving the area you want to mold on the fiberglass fender. Position it on the glass fender using the headlight bezel for proper location. Go to NAPA and get the epoxy adhesive called Plastic Welder, great stuff but you have to work fast once mixed. Glue the steel bucket to the glass fender in proper location. Once hardened I finished it off by mixing fiberglass resin and cut up cloth and blend in surfaces together. If you need pictures post your home email and I will send pics of mine. Take you time and good luck.
Re: ? about Fiberglass fender head light buckets? [Re: maximus] #1851532
06/18/15 12:48 AM
06/18/15 12:48 AM
mopar65 Offline OP
mopar65  Offline OP
well that sucks for me seeing how my finders are already painted.lol But i will do what i have to do to make them work. my email is mopar_65@hotmail.com thanks and look forward to the pics, thanks Mopar65
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851582
06/18/15 02:20 AM
06/18/15 02:20 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Where's Doc FiBerGlASS when ya need him??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851935
06/18/15 05:08 PM
06/18/15 05:08 PM
Indiana
Chryco69 Offline
Missing my hose
Chryco69  Offline
Missing my hose
Indiana
Why cant they just sell the damn headlight buckets installed already????
I am in the same situation. I am trying to mock up a set for my 68 Dart.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1851958
06/18/15 05:54 PM
06/18/15 05:54 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My Glass fenders had the front bucket area molded in. It would be easy to install the prefab fiberglass buckets but your painted right now so just be careful and then use black spray paint to hide your work..
You must grind a V at the edge and then lay some glass mat on the front and back. Two layers each side would do it and you can get all the stuff from Walmart. Just clamp it so it don't move, then mix the resin and Matt then lay it up and work the bubbles out before it drys. Spray paint black when done.
Re: ? about Fiberglass fender head light buckets? [Re: Chryco69] #1851984
06/18/15 06:22 PM
06/18/15 06:22 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Glasstek sells a nice headlight bucket and they will mount them in there fenders if you order them that way. Its for 67-69 dart.
Re: ? about Fiberglass fender head light buckets? [Re: OUTLAWSSAA] #1852008
06/18/15 07:05 PM
06/18/15 07:05 PM
fullmetaljacket Offline
Watch out, it is in the buckets where most of the weight lies in most but not all fenders.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1852111
06/18/15 09:29 PM
06/18/15 09:29 PM
mopar65 Offline OP
mopar65  Offline OP
I don't have a clue who made the fenders, my painter got them in a trade from somebody. one reason i put them on my 73 was becasue i got the front end off my 72 parts duster and the front fenders are usable but it was going to take time and money. So my painter had these available.But if its going to end up taking a lot of time and money to get the fiberglass buckets to work 0on my car, i will just put my 73 duster front end on, its fenders and hood need very little body work and then just paint them. Sounds like i might be in over my head on these fiberglass fenders. Did i for get to say i really suck at fabing stuff?? lol
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1852137
06/18/15 09:52 PM
06/18/15 09:52 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Mopar65. PM and private email sent with pictures. I had to use the steel ones because the fenders from US Source were real junk. The headlight buckets were 1/2" to far forward and 1 1/2" short on the bottom. The fender attaching flange had more waves in them than the Atlantic Ocean during a hurricane. Not to mention one was 1/4" to short in length. The profile of the fenders were off to the doors, so I had to make cuts in the bracing and re-fiberglass them into the correct position. Good thing I know how to repair them myself, otherwise they would have been out in the trash.
Re: ? about Fiberglass fender head light buckets? [Re: mopar65] #1852258
06/19/15 12:26 AM
06/19/15 12:26 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Keep the original metal fenders. The fiberglass ones don't save you much in weight if anything and the quality and fit is worse as you are seeing, plus the extra fab work.
Not worth the Effort on the front fenders on the A bodies, IMO Doors and hood , yes.
Re: ? about Fiberglass fender head light buckets? [Re: maximus] #1852326
06/19/15 01:45 AM
06/19/15 01:45 AM
mopar65 Offline OP
mopar65  Offline OP
I got your email and thank you very much for the pics and info.
Re: ? about Fiberglass fender head light buckets? [Re: Sport440] #1852331
06/19/15 01:55 AM
06/19/15 01:55 AM
mopar65 Offline OP
mopar65  Offline OP
Hey Sport440 how have you been? me about to pull my hair out over this car.lol Sport I went with the fiberglass fenders becasue i was wanting to put a 72 duster front-end on my car.I really like the looks of the 70-72 better than the 73+ cars.At the time i thought i was saving time and money going with the ones i have now,becasue my factory ones was going to take lots of time and money to fix. pulse at the time i did not have the money to buy a different set of fiberglass fenders. Also I ran out of time and money to have the rest of the duster done by the paint guy. So looks like i am going to have to learn how to do body work and paint my self Which is pretty scary.lol becasue i am really thinking hard about just putting the 73 front end on it. I am about ready to sell it and take up bird watching.
