727 trans lines end connections help please? #1849449
06/15/15 11:05 AM
06/15/15 11:05 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
blew a tranny line yesterday, going to make a new line, and not real bright on the fitting ends, can someone please tell me the correct size and type of fitting i need to hook up to my stock trans connection ( male threads come out of trans) and size type i need to put on other end lower radiator (also has male threads coming out) thank you for any help, need to order the correct fitting for each end so i can custom bend line thank you
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849477
06/15/15 11:48 AM
06/15/15 11:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Confused , there should be a brass flare fitting that screws into the trans and radiator , the threads into the trans and the radiator are female , the fitting that screws in is male . What is on it now , you didn't do something silly and run rubber lines did you ?
the trans is 1/8 npt , the rad I th9ink is the same ... the line is 5/16 , -4an
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849498
06/15/15 12:12 PM
06/15/15 12:12 PM
weymouth,mass.
weymouth,mass.
no no, just need to replace, the steel line cracked at radiator, could have used rubber hose or the braided steel lines hanging in garage, but was trying to just replace the steel with steel and add cooler which uses rubber line from radiator to cooler cooler back to radiator. and yes brass fitting coming out transmission and radiator, there the same size, just didn't know what size the -4 an sounds correct thanks, and will order the new radiator as soon as i get the dimensions from you, i think it will be much happier 26" with shroud.
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849593
06/15/15 02:16 PM
06/15/15 02:16 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Keep in mind the OEM brass fittings are the SAE 45 degree double flare if you intend to reuse them.
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849618
06/15/15 02:34 PM
06/15/15 02:34 PM
weymouth,mass.
weymouth,mass.
Thank you
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849643
06/15/15 02:57 PM
06/15/15 02:57 PM
I'd get some 5/16" steel line of a variety that is softer/easier to bend (its out there). cut to length/deburr. slip the female ferrule fitting on the line. single flare with your 45 deg flaring tool. eyeball the quality of the flare as it is the concave/convex cone to cone interface that seals & you want good/smooth/full contact there so no leaks on down the line
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849696
06/15/15 03:54 PM
06/15/15 03:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
What kind of car? You can order them prebent from places like fine lines, inline tubes, the right stuff, classic tube, etc. edit, oops, never mind i see you want to add a cooler sorry
Re: 727 trans lines end connections help please? [Re: meepmeep70] #1849745
06/15/15 05:24 PM
06/15/15 05:24 PM
weymouth,mass.
weymouth,mass.
Thanks guys, yes adding a cooler, the stock lines also run tight against external oil system, so will want to reroute some, will practice my flaring skills thank you for helping all
