Shout out for Lizzard Skin
#1847804
06/13/15 12:13 AM
06/13/15 12:13 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I cannot believe how quiet my GTX is now. I sprayed both lizzard skin products wherever it made sense to spray, which to me was...everywhere I could reach that was not a finished surface. I am running Dynomax VT's on 2 3/4" stainless pipe direct off the stock 5.7 exhaust manifolds. I am WAAAYYYYYYYYY happy with these results, try it, you'll like it
Driving modern convenience in classic beauty
Re: Shout out for Lizzard Skin
[Re: Darius]
#1847822
06/13/15 12:31 AM
06/13/15 12:31 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I have a pair of VTs in the box still. Have not had a chance to put them on. Glad you like them. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Darius]
#1848003
06/13/15 12:12 PM
06/13/15 12:12 PM
Darius
Sacramento, Ca
It is obviously heavier in the bucket and I would say, without looking it up, a 2 gal bucket (size it comes in) is about 30lbs+or-. I don't know how to compute the dry weight spread over so much surface but I would guess we did not ADD much more or even as much weight as a max amount of ,say, Dynomat.
[Re: Darius]
#1848362
06/13/15 10:51 PM
06/13/15 10:51 PM
Darius
Sacramento, Ca
Everywhere you mentioned for sure.Underside of the roof, inside the entire trunk under the package tray, I f I could reach it it was shot. Also the entire underside and up the rear wheel cans. Dean also shot expandable foam insulation in the C pillars and basically every cavity on the body he could reach, including the area in the footwell left and right, where the door hinges are.He made cutouts so the adjustment bolts are accessible. If you do this be sure to use a lightweight SOFT curing type of spray foam, it is white vs the more yellow type that dries hard. That type will "ripple" on you
[Re: Darius]
#1848561
06/14/15 09:59 AM
06/14/15 09:59 AM
Darius
Sacramento, Ca
There are 2 products, 1 for heat and one for sound. The spray on fairly smooth so you can paint over it, unlike bed liner. We used one bucket of each, 2 gal per bucket. It appears to be much lighter than bed liner. The stuff was invented during the development of the space shuttle by NASA so you know weight was a major consideration. Google it and visit their web site for more info that I can give.
