My wrecked trailer, the saga continues #1838273
05/31/15 10:40 PM
05/31/15 10:40 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It turns out there was no collision on my trailer, no fault in MI. So I get $1000 from the girls insurance on a mini-tort. I figure how hard can it be. It's like a roll cage, albeit a bent one. The floor came out pretty easy. Took a 100 mile round trip down to Jerry Lozon's and got some info and the parts. Jerry is a great guy, very helpful. Yesterday I stripped the door. Man is it heavy. When you remove the diamond plate and the 3/4" plywood it comes up by itself, FAST. Then torched out the rear cross member and trimmed the welds with the cut off wheel. Today I cut the door frame apart. Dollied out the bent center and made a jig to square it up. The uprights were pulled in 2" at the bottom. Got it all welded up. Had to borrow a port-a-power to spread the uprights at the latch as the were bowed 3/8". Tomorrow I'll tackle the new cross member after work.
Doug
Re: My wrecked trailer, the saga continues [Re: dvw] #1838276
05/31/15 10:42 PM
05/31/15 10:42 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
After the cut. Bent tie down support. Got it beat back to straight.
Re: My wrecked trailer, the saga continues [Re: dvw] #1838278
05/31/15 10:43 PM
05/31/15 10:43 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The door frame damage.
Re: My wrecked trailer, the saga continues [Re: dvw] #1838287
05/31/15 10:59 PM
05/31/15 10:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
OUCH!!!
Re: My wrecked trailer, the saga continues [Re: J_BODY] #1838319
05/31/15 11:46 PM
05/31/15 11:46 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Man that really sucks ------ I'm sure you will get it fixed and done right though.
So your insurance would not cover the damage? I'm going to have to check into mine but think I have mine covered in a case like you had.
Re: My wrecked trailer, the saga continues [Re: dvw] #1838322
05/31/15 11:52 PM
05/31/15 11:52 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The door frame cut. The door frame jigged up.
Re: My wrecked trailer, the saga continues [Re: dvw] #1838323
05/31/15 11:53 PM
05/31/15 11:53 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
door frame done.
Re: My wrecked trailer, the saga continues [Re: dvw] #1838424
06/01/15 03:19 AM
06/01/15 03:19 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
In New York the no fault applies to medical coverage. Liability % still applies.
Either way your doing a good job!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: My wrecked trailer, the saga continues [Re: hemi-itis] #1838477
06/01/15 09:38 AM
06/01/15 09:38 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
When you get it done, it will be nicer than it was when it was new ..
Thats BS on the no fault crap
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: My wrecked trailer, the saga continues [Re: dvw] #1838499
06/01/15 10:50 AM
06/01/15 10:50 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If your in a no fault state you special coverage on your trailer. I have mine covered. Looks good your doing your usual great work.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: My wrecked trailer, the saga continues [Re: dvw] #1841060
06/04/15 12:29 AM
06/04/15 12:29 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Progress continues. Got the rear cross member fitted and welded in. Figured out the geometry of the hinges since they were larger in diameter. After welding the hinges to the door it bowed in 1/2" at the bottom. Put a 4x4 under the center and 3 of us jumped on it, perfect. Set the door and got everything welded up.
Doug
Re: My wrecked trailer, the saga continues [Re: dvw] #1841085
06/04/15 12:52 AM
06/04/15 12:52 AM
BigFish69 Offline
BigFish69  Offline
For $35.00 a year you could have it insured for $5000.00
Re: My wrecked trailer, the saga continues [Re: dvw] #1841233
06/04/15 10:05 AM
06/04/15 10:05 AM
an8sec70cuda Offline
Looks nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My wrecked trailer, the saga continues [Re: dvw] #1841283
06/04/15 11:27 AM
06/04/15 11:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Once again I'm reminded that everyone in the world has way more skills than I do. It's going to be better than new soon!
Re: My wrecked trailer, the saga continues [Re: dvw] #1841380
06/04/15 01:22 PM
06/04/15 01:22 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
I guess I missed a previous thread, Doug. When did this happen? The repair job looks great.
Dennis
Re: My wrecked trailer, the saga continues [Re: dvw] #1841384
06/04/15 01:25 PM
06/04/15 01:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
nice job up
Re: My wrecked trailer, the saga continues [Re: cudaboy] #1841845
06/05/15 12:32 AM
06/05/15 12:32 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Dennis
3 Fridays ago on the way to Milan. Got it all painted tonight. Ready to reskin starting tomorrow.
Doug
Re: My wrecked trailer, the saga continues [Re: dvw] #1844352
06/08/15 05:57 PM
06/08/15 05:57 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Got the frame painted, trim straightened (best I could) and the door is done. Even changed out the LR last side panel. Still have to finish the floor, change out the RS side panel and the rear taillight trim.
Doug
Re: My wrecked trailer, the saga continues [Re: dvw] #1844368
06/08/15 06:22 PM
06/08/15 06:22 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Nice work there doug. I thought for sure that was you I saw going to Milan sunday there was a rig just like yours heading out but when I got there it wasn't you. I was looking forward to see you as we were there testing 2 cars. So I had my hands full. So I take it you haven't tried that other set up on your car yet???
JAKES AUTOMOTIVE
Re: My wrecked trailer, the saga continues [Re: dvw] #1844380
06/08/15 06:35 PM
06/08/15 06:35 PM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
Looks good up you do nice work.
Any chance you'll have it done for this weekend?
DD reunion @ Milan?
Gary
