Chassis Dyno ? #1843216
06/07/15 01:26 AM
06/07/15 01:26 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I have an opportunity to put the Daytona on a chassis dyno next Saturday. A friend of mine who owns a shop. Is having a dyno day for his customers. He stopped by today and ask if I wanted to put my car on it. Would this be a good idea? Can you run slicks on a dyno? Jim
Re: Chassis Dyno ? [Re: rt66jim] #1843220
06/07/15 01:35 AM
06/07/15 01:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pump the air pressure up in the slicks.. a loose
conv give you some iffy numbers down lower
wave
Re: Chassis Dyno ? [Re: rt66jim] #1843224
06/07/15 01:38 AM
06/07/15 01:38 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Put some tiny radials on it and over inflate them. The slicks will hurt the #'s.
Re: Chassis Dyno ? [Re: gsmopar] #1843360
06/07/15 12:40 PM
06/07/15 12:40 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Why do the slicks hurt the numbers?
Re: Chassis Dyno ? [Re: rt66jim] #1843537
06/07/15 05:31 PM
06/07/15 05:31 PM
AndyF Online content
AndyF  Online Content
I wouldn't run slicks on a chassis dyno. Best bet is to get some good radial tires and fill them to the max sidewall pressure. Then you can strap the car down hard to keep it from moving around.
If you have a high stall converter in there then the numbers will be weird anyway. Might not even be worth the hassle of running it on a chassis dyno.
Re: Chassis Dyno ? [Re: AndyF] #1843691
06/07/15 09:13 PM
06/07/15 09:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I had the Hoosier QTP's on my dart when I dynoed it and an 8" vert and it showed 478 tq and similar hp running hi 9`s at 3200 lbs. which seems off to me and others I talked to about it.
Re: Chassis Dyno ? [Re: rt66jim] #1843943
06/08/15 02:03 AM
06/08/15 02:03 AM
WI
mopar873 Offline
mopar873  Offline
WI
Don't run the slicks. If you're lucky, you will have junk tires when you're done and lower numbers than expected. If you don't get lucky you may be in the market for new quarter panels. When they cinch down the tires hard, it takes away the tires ability to"grow" and all the pressure and expansion hits the sidewall creating a ton of pressure and heat.
Grab some wheels with radials on them and run good pressure and you'll be happy you did.
Re: Chassis Dyno ? [Re: mopar873] #1844043
06/08/15 09:41 AM
06/08/15 09:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess some of you have money for extra tires.. I
ran on the slicks each time on the dyno.. and the
quarters are still there.... but my junk was only
high 8s
wave
Re: Chassis Dyno ? [Re: MR_P_BODY] #1844057
06/08/15 10:06 AM
06/08/15 10:06 AM
WI
mopar873 Offline
mopar873  Offline
WI
Nah I just ran a cheap takeoff wheel on my trans am that was larger diameter than the race wheels but with a stock tire was still very similar overall height. I got that info the first time I was going to chassis dyno. I was ordering some bias ply MT ET Streets and between what the tire manufacturer told me and what the dyno operator said I listened close. My take offs for running the dyno were less than 50 bucks and I didn't want to take a chance of a slick blowing out a sidewall.
The manufacturers advice made sense, wrinkle walls aren't designed to balloon way out. The sidewalls get overstretched and the wrinkle wall rebound is affected in the future. Since then I've seen some single digit cars completely frag a set of slicks on chassis dynos. At the end of one or two runs they're coming apart.
I'm not knocking your advice. In fact I've read your feedback with great respect over the last several years smile.
I'm just paranoid about safety I guess.
Re: Chassis Dyno ? [Re: mopar873] #1844062
06/08/15 10:18 AM
06/08/15 10:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
IF I didnt have other tires then I would run the
slicks.. but if I did I would change over.. I put
cars on dynos everyday for 25+ years.. you dont have
to have them pulling down so hard it hurts things..
its all in the angles of the straps
wave
Re: Chassis Dyno ? [Re: MR_P_BODY] #1844080
06/08/15 11:19 AM
06/08/15 11:19 AM
MT PLEASANT, IA
BARRACUDA340S Offline
MT PLEASANT, IA
If you're looking for accurate numbers don't bother with a converter. Like others said it makes things weird. Can't help on the tire situation but if you can put a wideband in the exhaust it would be worth seeing how your tune is. Might be some useful data there.
