Best sealing LA Small Block Header Gaskets? #1841518
06/04/15 04:20 PM
06/04/15 04:20 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
Which brand of exhaust header gaskets seal best for a 360 LA Small Block? Thanks.
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841770
06/04/15 10:36 PM
06/04/15 10:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
clean head and flat flange and I've had good luck with about anything out there.
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841771
06/04/15 10:40 PM
06/04/15 10:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My tti gaskets that came with the headers have been on for 10 years without a leak, probably due to the header more than the gasket.
Re: Best sealing LA Small Block Header Gaskets? [Re: ademon] #1841779
06/04/15 10:53 PM
06/04/15 10:53 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
I got some jacked up headers on the Duster, I used Remflex they are quite a bit thicker and a bit spendy
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841782
06/04/15 10:55 PM
06/04/15 10:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I like the tti gaskets.
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841789
06/04/15 11:04 PM
06/04/15 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A good thick flange of 3/8" and I have used the
MP grafoil.. also one of the bolt holes per tube
enlarged to let it slide .. and a coat of hi temp
silicone
wave
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841842
06/05/15 12:27 AM
06/05/15 12:27 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Hands down these... Multi layered soft aluminum. Seal fantastic on my turbo car with huge back pressure compared to an n/a motor.
http://m.summitracing.com/parts/php-66037
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841885
06/05/15 01:18 AM
06/05/15 01:18 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I like cometic gaskets, hold up to the nitrous heat no problems.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841897
06/05/15 01:43 AM
06/05/15 01:43 AM
md
mopars4ever Offline
mopars4ever  Offline
md
TTI gaskets on mine for 8 years or so.
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841937
06/05/15 04:32 AM
06/05/15 04:32 AM
D_C Offline OP
D_C  Offline OP
Appreciate all the great advice, recommendations and tips.
Thanks Again
Re: Best sealing LA Small Block Header Gaskets? [Re: D_C] #1841948
06/05/15 05:55 AM
06/05/15 05:55 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Anyone know if any of these products can be had in bulk? I have to hand punch mine, as they are one-off.
Re: Best sealing LA Small Block Header Gaskets? [Re: dizuster] #1841957
06/05/15 07:45 AM
06/05/15 07:45 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
These are the best that I've found. thumbs
Re: Best sealing LA Small Block Header Gaskets? [Re: Leigh] #1841968
06/05/15 08:58 AM
06/05/15 08:58 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
You can buy Remflex in different size sheets. I see it on Remflex's site and on Summit's.
