Kelsey Hayes Disc Brakes without a booster? #184114
01/04/09 09:05 PM
01/04/09 09:05 PM
New York
R/T1968R/T Online happy OP
R/T1968R/T  Online Happy OP
New York
Maybe a silly question, but can you run the early 68-69 Kelsey Hayes without a power booster? If not can you just change the master cylinder to exit on the fender side? Thanks!! Yes they are the four piston calipers.
Re: Kelsey Hayes Disc Brakes without a booster? [Re: R/T1968R/T] #184115
01/04/09 09:31 PM
01/04/09 09:31 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
my 69 car came factory with NON power disc brakes! [on the fender tag also] so yes! they are very nice feeling with no power also! cant help on the MCYL sorry dan
Re: Kelsey Hayes Disc Brakes without a booster? [Re: R/T1968R/T] #184116
01/04/09 09:33 PM
01/04/09 09:33 PM
Edmonton , Alberta
swingin Offline
swingin  Offline
Edmonton , Alberta
Do you mean the four piston calipers? If so, I've got them on my Dart with no booster. I used a late model m.c., and they seem to work alright....
Re: Kelsey Hayes Disc Brakes without a booster? [Re: swingin] #184117
01/04/09 11:06 PM
01/04/09 11:06 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Yes you can as I removed the booster on my gtx many years ago and it stops just fine with no power assist.
Re: Kelsey Hayes Disc Brakes without a booster? [Re: R/T1968R/T] #184118
01/05/09 12:29 AM
01/05/09 12:29 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Make sure you remove the power booster linkage on the brake pedal if you have it. The manual brake cars don't come with it installed. After removal the pedal ratio will be right around 6 -1 which is good for manual disc brakes.
Re: Kelsey Hayes Disc Brakes without a booster? [Re: Lefty] #184119
01/05/09 12:50 AM
01/05/09 12:50 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
My 67 Dart GTS came from the factory with Kelsey Hayes 4 piston Discs with no booster, just as I ordered it.
Maynard
Re: Kelsey Hayes Disc Brakes without a booster? [Re: DartGTS] #184120
01/05/09 02:26 AM
01/05/09 02:26 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Same here,
69 GTS with non power assist KH 4 Piston disc.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Kelsey Hayes Disc Brakes without a booster? [Re: GTSDave] #184121
01/05/09 12:45 PM
01/05/09 12:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They work great without the booster. My old 66 Barracuda came that way. Also, they were used from 65-72 on a-bodies, not just 68-69.
Re: Kelsey Hayes Disc Brakes without a booster? [Re: R/T1968R/T] #184122
01/06/09 12:10 PM
01/06/09 12:10 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Yep. running them on my 69 RR with no booster. Seem to work fine.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
