Steering Column Question: 69 Charger
#1840495
06/03/15 02:34 PM
06/03/15 02:34 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Hello, restoring the steering column out of a 69 Charger, Auto, console steering column. Hope the pic comes out so you can see what Im talking about, but the problem is in the top of the column casting which has the bearing and also contains the turn signal switch. Also known as the bearing housing. There are two bolts that have tapered square heads that insert from behind, and on top, nuts with 6 cuts across them. The problem is that the nuts wont run all the way up the bolts because of a non threaded shoulder. Cant remember what the bolts are suppose to attach to, only that they go thru the housing. Its a mystery. Thanks for any help.
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Steering Column Question: 69 Charger
[Re: 69rrgrabber]
#1840828
06/03/15 08:56 PM
06/03/15 08:56 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Don't they hook into the tube to pull it up tight. Not sure I can remember being in one from a B-body but several columns with bolts that retain the bowl entering from the back. I may have a pictoral break down on one, if I do I will post.
Good luck.
Careful, your character's showing!
[Re: 69rrgrabber]
#1841166
06/04/15 03:41 AM
06/04/15 03:41 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Thank God for you guys! Ok I took the middle section out and see now how the square heads go into the square holes on the lower tube section. Haven't quite figured out how to put all 3 sections together, I'm held up by the middle section / housing, not sitting flush on the lower tube housing. Just below the middle housing is a wavy washer and below that a thin collar retainer with 4 raised teeth. The manual has a diagram which show them facing down towards the housing, but it just dosent fit. Think I'll call it a night and try fresh tomorrow.
Thanks, Carl
1970 Cuda 440
[Re: 69rrgrabber]
#1841924
06/05/15 02:55 AM
06/05/15 02:55 AM
Posts: 352 Arizona
69rrgrabber
Arizona
David, got it all together, thanks again for the pics and help!
1970 Cuda 440
