SB MOPAR HEAD #1836424
05/29/15 02:13 AM
05/29/15 02:13 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i was working on a new sb mopar head 240 cc intake and flow around 340 at 700 lift but after a pheasable study was done and the market is just not there for them so we canceled it sorry guys i tried
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: SB MOPAR HEAD [Re: Ian] #1836454
05/29/15 03:56 AM
05/29/15 03:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: SB MOPAR HEAD [Re: J_BODY] #1836477
05/29/15 07:10 AM
05/29/15 07:10 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
Originally Posted By J_BODY
cheap now ask brett miller how much to finlish them off lol
Re: SB MOPAR HEAD [Re: Ian] #1836652
05/29/15 02:01 PM
05/29/15 02:01 PM
dogdays Offline
dogdays  Offline
What the world needs now is a 340 Race block that can actually be bolted together without major machine work.... There are enough heads that make more power than the blocks can stand, right now.
R.
Re: SB MOPAR HEAD [Re: dogdays] #1838504
06/01/15 11:12 AM
06/01/15 11:12 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's disappointing, but I can't say I am surprised. If everything is outsourced (Patterns, casting, final machining), there will be a bunch of money out laid before you would see any ROI. To top it off, ROI would be slow, if you made it all back.
Alan Jones
Re: SB MOPAR HEAD [Re: Ian] #1838648
06/01/15 01:16 PM
06/01/15 01:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
360-1s already do that so it would have to be substantially more to make any sense.
Re: SB MOPAR HEAD [Re: Quicktree] #1839378
06/02/15 12:29 AM
06/02/15 12:29 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
these would have been around 1500 a pair bare cnc heads we where trying to make it more affordable for the average racer
Re: SB MOPAR HEAD [Re: Ian] #1839388
06/02/15 12:39 AM
06/02/15 12:39 AM
Toronto
mshred Offline
mshred  Offline
Toronto
What market did you guys research? Those numbers at that price, I am sure you would have had swarms of guys on those like a fat kid on cake!
Re: SB MOPAR HEAD [Re: mshred] #1839450
06/02/15 01:30 AM
06/02/15 01:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
iagree For $1500 a pair you couldn't keep them on the shelf. IMO the SBM market is stale, we need good blocks the most and a canted valve head that will flow in the 380s or more. I know.....I know, it won't look like an X head and the ports would like a BBC or a Ford and the rockers wouldn't all be on the same shaft. I don't give a $hit!!! Go ahead and tell me about the Gen III Hemi, I have yet to see one running in an old car at any local drag strip.
Hey I can dream can't I? Now where did I leave my crack pipe....... biggrin
Re: SB MOPAR HEAD [Re: Ian] #1839455
06/02/15 01:43 AM
06/02/15 01:43 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
68 Dart in Vegas has a Gen III 5.7 hemi....runs 12.40s in Vegas air..
Tony
70 AARCuda Vitamin C
Re: SB MOPAR HEAD [Re: 70AARcuda] #1839458
06/02/15 01:48 AM
06/02/15 01:48 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's good for probably a stock 5.7, but not what most are looking for. The new Hemi is a great engine, just not a ton of parts out there yet. 6.1 blocks?
Re: SB MOPAR HEAD [Re: Ian] #1839764
06/02/15 02:57 PM
06/02/15 02:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There are plenty of genIII parts, they are just real expensive. I have a set of eagle heads 2 sets of early 5.7 heads, 2003 and 2011 injectors and everything to assemble an engine for a pickup or durango but the cost of the stuff to put it in something old is very cost prohibitive.
Oil pan
Headers, I can't find any manifolds to fit an early car.
Ign controller
Carb intake, even the crappy ones cost $500+ a decent one is $1000
EFI controler and harness, even if I use my 03 computer it is not cheap to set up.
Engine mounts
Engine accessories
I think I figured out a way to hook it to a 904 cheap (Jeep converter, 5.7 flex plate) unless someone knows why this won't work.
A 6.1 block is not needed for most guys, the line of site flow path the air takes to the center of the cylinder is not affected much at all by the smaller bore, look at the 2014 engine masters competetion for proof. They ran GINOURMOUS heads on 5.7 blocks and mopped up not just power per cube but low end TQ and all out HP were awesome. Even the Kass ferd hemi had bores about the size of a 273 and came in 5th place. Bore size is just not as critical on a hemi as a wedge.
