Re: SB MOPAR HEAD
[Re: Ian]
#1836454
05/29/15 03:56 AM
05/29/15 03:56 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Re: SB MOPAR HEAD
[Re: dogdays]
#1838504
06/01/15 11:12 AM
06/01/15 11:12 AM
Posts: 6,146 Melbourne , Australia
LA360
It's disappointing, but I can't say I am surprised. If everything is outsourced (Patterns, casting, final machining), there will be a bunch of money out laid before you would see any ROI. To top it off, ROI would be slow, if you made it all back.
Alan Jones
Re: SB MOPAR HEAD
[Re: Ian]
#1838648
06/01/15 01:16 PM
06/01/15 01:16 PM
Quicktree
i was working on a new sb mopar head 240 cc intake and flow around 340 at 700 lift but after a pheasable study was done and the market is just not there for them so we canceled it sorry guys i tried 360-1s already do that so it would have to be substantially more to make any sense.
Re: SB MOPAR HEAD
[Re: Quicktree]
#1839378
06/02/15 12:29 AM
06/02/15 12:29 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
i was working on a new sb mopar head 240 cc intake and flow around 340 at 700 lift but after a pheasable study was done and the market is just not there for them so we canceled it sorry guys i tried 360-1s already do that so it would have to be substantially more to make any sense. these would have been around 1500 a pair bare cnc heads we where trying to make it more affordable for the average racer
Re: SB MOPAR HEAD
[Re: Ian]
#1839388
06/02/15 12:39 AM
06/02/15 12:39 AM
Posts: 3,415 Toronto
mshred
Toronto
i was working on a new sb mopar head 240 cc intake and flow around 340 at 700 lift but after a pheasable study was done and the market is just not there for them so we canceled it sorry guys i tried 360-1s already do that so it would have to be substantially more to make any sense. these would have been around 1500 a pair bare cnc heads we where trying to make it more affordable for the average racer What market did you guys research? Those numbers at that price, I am sure you would have had swarms of guys on those like a fat kid on cake!
Re: SB MOPAR HEAD
[Re: Ian]
#1839455
06/02/15 01:43 AM
06/02/15 01:43 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
68 Dart in Vegas has a Gen III 5.7 hemi....runs 12.40s in Vegas air..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: SB MOPAR HEAD
[Re: 70AARcuda]
#1839458
06/02/15 01:48 AM
06/02/15 01:48 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
68 Dart in Vegas has a Gen III 5.7 hemi....runs 12.40s in Vegas air.. That's good for probably a stock 5.7, but not what most are looking for. The new Hemi is a great engine, just not a ton of parts out there yet. 6.1 blocks?
Re: SB MOPAR HEAD
[Re: Ian]
#1839764
06/02/15 02:57 PM
06/02/15 02:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
There are plenty of genIII parts, they are just real expensive. I have a set of eagle heads 2 sets of early 5.7 heads, 2003 and 2011 injectors and everything to assemble an engine for a pickup or durango but the cost of the stuff to put it in something old is very cost prohibitive.
Oil pan Headers, I can't find any manifolds to fit an early car. Ign controller Carb intake, even the crappy ones cost $500+ a decent one is $1000 EFI controler and harness, even if I use my 03 computer it is not cheap to set up. Engine mounts Engine accessories
I think I figured out a way to hook it to a 904 cheap (Jeep converter, 5.7 flex plate) unless someone knows why this won't work.
A 6.1 block is not needed for most guys, the line of site flow path the air takes to the center of the cylinder is not affected much at all by the smaller bore, look at the 2014 engine masters competetion for proof. They ran GINOURMOUS heads on 5.7 blocks and mopped up not just power per cube but low end TQ and all out HP were awesome. Even the Kass ferd hemi had bores about the size of a 273 and came in 5th place. Bore size is just not as critical on a hemi as a wedge.
