70 Challenger Shaker Trim Ring #1838960
06/01/15 05:17 PM
06/01/15 05:17 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
I have a very simple question
how can you visual identify an AMD trim ring from an original
I am guessing that there is small pt# casted into the originals but not sure if a later NOS one could be w/o a pt#.
what is the correct length of the studs that get nutted under the hood?
if anyone could post good pics I would appreciate it greatly.
I might have me an issue and want to get my ducks lined up before I get on the phone.
thanks in advance.
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: 70 Challenger Shaker Trim Ring [Re: 72ls5fla] #1839042
06/01/15 06:13 PM
06/01/15 06:13 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
There is indeed a part number on an original as well as pentastar, and 7 digit vendor code all found together on the bottom srea of an original Challenger trim ring.
AMD nor any other reproduction Challenger trim ring has any numbers on them and are made of aluminum whereas originals are made of zinc.
There are reproduction Cuda trim rings with all the numbers like original Cuda but no has done that in Challenger.
Original zinc ring is quite a bit heavier than an aluminum ring obviously.
Studs are about 1/16 - 1/8 longer on the repro.
Re: 70 Challenger Shaker Trim Ring [Re: mccannix] #1839081
06/01/15 06:42 PM
06/01/15 06:42 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Terry do you have the part numbers for the cuda and challenger trim rings?
Re: 70 Challenger Shaker Trim Ring [Re: mccannix] #1839184
06/01/15 08:08 PM
06/01/15 08:08 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thanks for the info - greatly appreciate it
btw... I found out my ring is a repro one.
any chance the original trim ring is a little bit taller than the repro one does?
only asking because i can see more of the shaker bubble and the scripts on the side sit up above the ring more.
before i had the car worked on, they sat a bit lower in the hole....
there seems to be a bout a 1/8" or so difference on the height above the hood, with the one on my car being lower.
bill
Re: 70 Challenger Shaker Trim Ring [Re: 72ls5fla] #1839474
06/02/15 01:23 AM
06/02/15 01:23 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Challenger trim ring part number 3443168
Cuda trim ring part number 3514076
Re: 70 Challenger Shaker Trim Ring [Re: 72ls5fla] #1845249
06/09/15 07:55 PM
06/09/15 07:55 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Challenger
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 70 Challenger Shaker Trim Ring [Re: 72ls5fla] #1845341
06/09/15 09:14 PM
06/09/15 09:14 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
A spare `cuda one I have hanging around.
cudaized.com
Re: 70 Challenger Shaker Trim Ring [Re: 72ls5fla] #1845351
06/09/15 09:21 PM
06/09/15 09:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct on both the casting numbers and part#s (they are typically one digit off on the last number like that).
