Page 2 of 4 1 2 3 4
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836752
05/29/15 04:07 PM
05/29/15 04:07 PM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
Can always do a car wrap, don't know the cost though.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836755
05/29/15 04:08 PM
05/29/15 04:08 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Originally Posted By gdonovan
So sand, fix the one ding, 2k primer (the whole car or just that area?) sand again and then hit it with epoxy primer?
If the ding isn't terrible, you may look into having a paintless dent repair person fix it before you paint. That would save you some material cost and time.
Otherwise, you will spot prime the repair area(s) so that it fills the scratches left in the plastic filler. I typically finish plastic to 180. Finish out the primer to 320 dry like the rest of the car, and epoxy prime. That will do several things; act as a uniform basecoat before the topcoat, tie all the coats together chemically, bite into the 320 scratches so that the paint doesn't delam like before. Nice thing is most epoxy primers stay "open" from 3-7 days so you can get the topcoat on at your leisure or as weather permits. If you wait beyond that window, you have to wet sand and re-epoxy.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Paint guys- I'm behind the eight ball [Re: herkamer] #1836772
05/29/15 04:29 PM
05/29/15 04:29 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
It really is small.
"I think its got a hemi"
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836778
05/29/15 04:49 PM
05/29/15 04:49 PM
MD
p d'ro Offline
p d'ro  Offline
MD
I plasti dipped my Bronco where's but probably wouldn't do it to a car as it peels super easily. Although just spray more on?
Either way good luck with it. I know they have a niche but don't sink too much in as there is a low ceiling
Re: Paint guys- I'm behind the eight ball [Re: feets] #1836780
05/29/15 04:52 PM
05/29/15 04:52 PM
dogdays Offline
dogdays  Offline
My point was that there is a middle ground between a roller or rattlecan paint job and the $3000 job, also that there ARE MAACO shops in CT. I just picked one of them, not knowing where you are. But it seems you enjoy the problem. It's all yours.
Oh, and one more thing...rare Shelby parts? There is rare, and then there is rare and valuable.
Don't bother to flame, I'm gone from this thread.
R.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836786
05/29/15 05:01 PM
05/29/15 05:01 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I don't know what a PDR guy would charge to fix it, but I would bet it would be less than a quart of plastic filler, quart of primer, hardener etc. If you get the door panel off and ready for them that might save you a couple bucks too.
Matt
69 Dart Swinger 340
and even more
Re: Paint guys- I'm behind the eight ball [Re: dogdays] #1836791
05/29/15 05:19 PM
05/29/15 05:19 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
1) I agree with you, there is a middle ground.
2) Yup, there is three in the whole state and the one you posted is the closest and just happens to be smack dab in the middle of the worst areas of Hamden.
High crime area would be a vast understatement and I would know this as I have friends who live not far from there. Crackheads even stole a worthless set of rims off the front of the Reliant while it was in a shop getting welding done on the cage.
Nope, I'm realistic about prospects so have to explore all options.
Oh, and one more thing...rare Shelby parts? There is rare, and then there is rare and valuable. .
Rare; as in impossible or difficult to find. I never stated a value of any sort.
Why the chip on the shoulder?
If the grill gets broken (they tend to be fragile) or lost I'm S.O.O.L. as there is no replacement and its rare they come up for sale as they only made 750 CSX in 1987.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836809
05/29/15 05:55 PM
05/29/15 05:55 PM
Spokane Valley WA
dan6412 Offline
dan6412  Offline
Spokane Valley WA
I paint alot of fleet trucks and I think your idea is very good, do a good prep job, and use the summit primer and paint. I would prime the complete car using the primer as a sealer and surfacer. You said you havent painted in a few years so if you dont have one, I would go but a cheap gravity feed gun from Lowes or H.F. I use these when I dont want to use my "good" guns and they actully work very well and the newer paints dont do so well in the older siphon guns.
Dan
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836819
05/29/15 06:19 PM
05/29/15 06:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You'll have to follow the tech sheets for whatever products you plan to use. For my last two paint jobs, I have used the products from www.tcpglobal.com and www.autocolorlibrary.com I have used their "restoration shop" brand primers (epoxy primer as well as 2k urethane primer) and their brand paint in both their pre-packaged color as well a factory color.
My method was:
-Sand body down with 320 to scuff it up good, burn off clear coat, etc.
-Do the body work, metal repairs, welding, filler(shape with 220, finish with 320), etc
-Epoxy primer
-2k urethane primer
-Block sand 400 - the urethane primer sands nice and easy plus super smooth.
-Paint
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1836872
05/29/15 07:56 PM
05/29/15 07:56 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
If you know how to use your spray gun (and it's a decent model, not a cheapie) I would say sand it and go for it...
I have a decent gun but had no idea what I was doing. My Dart looks like I painted it with a Hershey bar and then threw handfuls of dust and dirt at it fan
I had a local guy (one-man "custom" shop) do half my beater BMW (hood, roof and trunk) and blend the clearcoat down to the moldings on the fenders and rear quarters. I saved a lot of money by doing the sanding myself (almost ten hours with a DA and sanding block). The paint and clear coat cost me $270 and his labor for the rest was a very reasonable $400. Came out nice, although I wish I had been able to feel/see the several hail dings first! (That would have cost more, of course).
Here's the BMW, I won't show you the Dart because it's too embarrassing. whistling
Before (no clear coat and very little paint left on the roof and trunk):
After the sanding:
And after the guy who knew what he was doing painted it:
Well worth $400 to me not to mess it up and have to start all over! Not to mention building a paint booth from plastic sheet and lumber.
I have learned that painting cars is as much art as science and I don't have enough time, money or inclination to learn how to do it "right". I'm going to sand the Dart and have him paint it too.
Re: Paint guys- I'm behind the eight ball [Re: DrCharles] #1837014
05/30/15 12:12 AM
05/30/15 12:12 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I would do it in SPI expoxy primer - nice satin sheen , UV inhibiters, easy to scuff and spray later, reasonably priced or dupli color paint from advanced auto - kinda like a hybrid lacquer - not real durable but fast, cheap and nothing fancy to spray
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837031
05/30/15 12:33 AM
05/30/15 12:33 AM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
Just my opinion, but if you are not experienced with a spray gun a flat black paint job will most likely not come out well. Everyone seems to think that flat black is easy. If you dont have good overlap while spraying, it will be all kinds of streaky. I'd leave it alone until you have a chance to do it right.
Re: Paint guys- I'm behind the eight ball [Re: Mopargnome] #1837148
05/30/15 08:11 AM
05/30/15 08:11 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Can't.
Insurance company won't insure the car without it being painted. They are afraid it is going to be used as a daily driver.
Car needs to be in PA first week of July running correct which is still up in the air.
I am considering just putting liability insurance on the car which I can get now.
Original paint guy got back to me stating "we will make something happen" when I told him it was getting done at home and will have new answer today.
Perhaps he did not take me serious about my stated timeframe.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837286
05/30/15 01:55 PM
05/30/15 01:55 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Personally, I'd just leave it alone. There are going to be a bunch of freshly painted cars at the show. If you need time and still have to fix all of the mechanical problems, just fix what needs to be fixed to get the car running safely. If you really care how it looks, get a vinyl wrap. You can remove it later down in life and paint the car then when your shop or yourself have more free time.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837310
05/30/15 02:30 PM
05/30/15 02:30 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
I would leave it the way it is and put any money into mechanicals. I would love to see a car like that racing in its original paint. If you paint it, it will look like all the other cars on the track. Leave it alone!
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837319
05/30/15 02:37 PM
05/30/15 02:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Reminds me of the old mantra "if it don't go chrome it".
Re: Paint guys- I'm behind the eight ball [Re: stumpy] #1837332
05/30/15 03:01 PM
05/30/15 03:01 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
'cept I build FWD cars that GO.
Plenty of hardware lying about the shop to turn this into an easy 11 second ride. I'm trying not too as the kids don't need to be wrapping themselves around trees.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837347
05/30/15 03:51 PM
05/30/15 03:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
My point is make it start stop and steer and run correctly before worrying about how it looks.
Re: Paint guys- I'm behind the eight ball [Re: stumpy] #1837474
05/30/15 08:34 PM
05/30/15 08:34 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Starting and stopping already done (has brand new brakes on all four corners plus new struts and shocks)
Paint needs to get done next for two reasons- One the insurance company won't insure it unless it is in paint. Two, I can't do a windshield till the paint is done as the trim is held in by the windshield and covers the paint and I have the last trim set available in the USA.
Turbo and rack being done at same time because it is easy to do the turbo while k-frame is down. The new turbo isn't here yet so no reason to pull the k-frame till it shows up.
Re: Paint guys- I'm behind the eight ball [Re: gdonovan] #1837476
05/30/15 08:39 PM
05/30/15 08:39 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Just wrap the car then.
Page 2 of 4 1 2 3 4
