Re: Ball and trunnion drive shaft conversion
[Re: 6T4 Polara]
#1836844
05/29/15 07:12 PM
05/29/15 07:12 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Just FYI the ball and trunion design is quite strong, stronger than a reg u joint if I recall.....So if a CV boot will work save yourself $$Hundreds and use it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 6T4 Polara]
#1836845
05/29/15 07:15 PM
05/29/15 07:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Found a shop and all set to go with the upgrade.
Thanks Not really an upgrade. If you need a boot www.oldmoparts.com has the correct ones and not a CV joint on that may not work as well.
[Re: 6T4 Polara]
#1837074
05/30/15 01:30 AM
05/30/15 01:30 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Rick you are right the B&T is strong.My 65 broke quite a few rear joints but still has the OE front.My kids 62 300 was the same way.I still have the oe boot on mine.I used a leather replacement boot on my 57 Chrysler and it worked good.I think I have one NOS repair kit.Might even have the shaft from the 62 as my kid went to new trans and Dennys shaft.Rocky
Chrysler Firepower
[Re: 6T4 Polara]
#1837258
05/30/15 01:09 PM
05/30/15 01:09 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
When I got my '64 Polara it had the keyed axle in the back and the B&T front u-joint. I did not like either one and built a Dana 60 for the rear and had a local 727 guru build my 727 with a '65 extension housing and mainshaft that allowed a slip yoke driveshaft that I also had made up. It was never my daily driver, I had the money then to do it and friends to help with the engineering. I was also 18 years younger, that helped a lot.
I am still playing with Mopars and now I have a better place to do it
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: HemiRick]
#1837875
05/31/15 11:55 AM
05/31/15 11:55 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Just FYI the ball and trunion design is quite strong, stronger than a reg u joint if I recall.....So if a CV boot will work save yourself $$Hundreds and use it. I haven't heard that before, interesting.
[Re: 6T4 Polara]
#1838765
06/01/15 03:31 PM
06/01/15 03:31 PM
therocks
Niles , Ohio
In 50 years Ive seen one B&T broke.It was dry as no grease.Greased and clean and they are pretty much unbreakable.Rocky
Chrysler Firepower
