Ball and trunnion drive shaft conversion #1836486
05/29/15 09:02 AM
05/29/15 09:02 AM
6T4 Polara Offline OP
What I have is a 1964 Dodge Polara with a ball and trunnion drive shaft in need of a boot.
I would like to have it converted to the style using a universal joint eliminating the ball and trunnion.
Any ideas or experience with a drive shaft service that can do this?
I am located south of Detroit.
John
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836527
05/29/15 10:50 AM
05/29/15 10:50 AM
New York
rarefish Offline
rarefish  Offline
New York
The only way the I know to use a drive shaft with a front U-Joint would be to have the output shaft of the tranny changed over to the 65 and newer spline shaft. I went through the same issue on my 64 Belvedere. When I had my tranny rebuilt the shop guy told me I could switch over to the modern drive shaft if I could supply him with a output shaft from a later trans. I had no access to one, so I'm still running the ball and trunnion shaft.
Re: Ball and trunnion drive shaft conversion [Re: rarefish] #1836540
05/29/15 11:14 AM
05/29/15 11:14 AM
Onalaska, Wi
sixtyninefuchs Offline
Onalaska, Wi
Re: Ball and trunnion drive shaft conversion [Re: sixtyninefuchs] #1836583
05/29/15 12:08 PM
05/29/15 12:08 PM
New York
rarefish Offline
rarefish  Offline
New York
Well I just learned something.... Thanks
Re: Ball and trunnion drive shaft conversion [Re: rarefish] #1836705
05/29/15 03:04 PM
05/29/15 03:04 PM
Found a shop and all set to go with the upgrade.
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836804
05/29/15 05:48 PM
05/29/15 05:48 PM
New York
rarefish Offline
rarefish  Offline
New York
6T4 Polara let me know how it work out for you and what it ends up costing. I might also go that route.
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836813
05/29/15 06:01 PM
05/29/15 06:01 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
I used a Dorman 614 002 universal cv boot kit on last `64 Fury I did and worked great.
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836831
05/29/15 06:37 PM
05/29/15 06:37 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've had a local shop make a new driveshaft based on the specs of the old B&T-driveshaft.;
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836844
05/29/15 07:12 PM
05/29/15 07:12 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Just FYI the ball and trunion design is quite strong, stronger than a reg u joint if I recall.....So if a CV boot will work save yourself $$Hundreds and use it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1836845
05/29/15 07:15 PM
05/29/15 07:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not really an upgrade. If you need a boot www.oldmoparts.com has the correct ones and not a CV joint on that may not work as well.
Don't be the exception.
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1837074
05/30/15 01:30 AM
05/30/15 01:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Rick you are right the B&T is strong.My 65 broke quite a few rear joints but still has the OE front.My kids 62 300 was the same way.I still have the oe boot on mine.I used a leather replacement boot on my 57 Chrysler and it worked good.I think I have one NOS repair kit.Might even have the shaft from the 62 as my kid went to new trans and Dennys shaft.Rocky
Chrysler Firepower
Re: Ball and trunnion drive shaft conversion [Re: therocks] #1837157
05/30/15 09:03 AM
05/30/15 09:03 AM
Upgrade for me I am to old to lay on the garage floor and remove the drive shaft. Yes I have done it and it did not last for whatever reason. The modification is my fix.
Thanks for all the replies.
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1837258
05/30/15 01:09 PM
05/30/15 01:09 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When I got my '64 Polara it had the keyed axle in the back and the B&T front u-joint. I did not like either one and built a Dana 60 for the rear and had a local 727 guru build my 727 with a '65 extension housing and mainshaft that allowed a slip yoke driveshaft that I also had made up. It was never my daily driver, I had the money then to do it and friends to help with the engineering. I was also 18 years younger, that helped a lot.
I am still playing with Mopars and now I have a better place to do it
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Ball and trunnion drive shaft conversion [Re: HemiRick] #1837875
05/31/15 11:55 AM
05/31/15 11:55 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I haven't heard that before, interesting. work
Re: Ball and trunnion drive shaft conversion [Re: 6T4 Polara] #1838765
06/01/15 03:31 PM
06/01/15 03:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
In 50 years Ive seen one B&T broke.It was dry as no grease.Greased and clean and they are pretty much unbreakable.Rocky
Chrysler Firepower
Re: Ball and trunnion drive shaft conversion [Re: therocks] #1839254
06/01/15 10:21 PM
06/01/15 10:21 PM
moparx Offline
moparx  Offline
i agree with rocky. the other thing i have seen in these joints has been when guys replace them that don't know what they are doing, they get fubared and end up off centered, which makes 'em short lived.
beer
