Help me pick a timing light
#1834969
05/27/15 12:32 AM
05/27/15 12:32 AM
Posts: 9,122 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
My old reliable dial back Snap on timing light quit working. I need a replacement. I want one I can roll the advance setting into and then read the timing marks at zero. For instance, if I want 10 degrees of initial timing, I simply enter 10 degrees in my light and and turn the distributor until the timing marks read TDC. I can't tell from reading the ads on these new-fangled light (yes, I'm becoming an old fart) if that is the case with them. Will this one do what I want? Is it easy to use? Any other suggestions on a timing light? http://www.summitracing.com/parts/ino-3568/overview/
Re: Help me pick a timing light
[Re: Ramrod39]
#1834971
05/27/15 12:35 AM
05/27/15 12:35 AM
Posts: 43,556 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I am right there with you. I lost all my tune-up equipment in my garage fire and I need to buy a new timing light, I will be watching this thread!
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1834981
05/27/15 12:50 AM
05/27/15 12:50 AM
RapidRobert
Not sure of a brand but I'd suggest stepping up & getting a dialback with a tach in the gun. You'll like it for serious curve mapping
[Re: Ramrod39]
#1835022
05/27/15 01:50 AM
05/27/15 01:50 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Do you use an MSD ignition? Some timing lights do NOT work w MSD.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Ramrod39]
#1835177
05/27/15 11:38 AM
05/27/15 11:38 AM
Posts: 216 E. Okla line
m88mark
E. Okla line
My dial back quit also. Bought OTC 3367,brite lite & flashlite button (handy). Still have to read instructions, but I still use a flip phone! Mark. My old reliable dial back Snap on timing light quit working. I need a replacement. I want one I can roll the advance setting into and then read the timing marks at zero. For instance, if I want 10 degrees of initial timing, I simply enter 10 degrees in my light and and turn the distributor until the timing marks read TDC. I can't tell from reading the ads on these new-fangled light (yes, I'm becoming an old fart) if that is the case with them. Will this one do what I want? Is it easy to use? Any other suggestions on a timing light? http://www.summitracing.com/parts/ino-3568/overview/
[Re: mopars4ever]
#1835973
05/28/15 01:57 PM
05/28/15 01:57 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I don`t know about these new modern timing lights but my old craftsman dial back works fine with MSD. That is the one that I have and the last time it was used the inductive clamp melted a little to the header...but it still works just fine.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Ramrod39]
#1837139
05/30/15 04:16 AM
05/30/15 04:16 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I bought the best one Innova has, the 5568. It is awesome, it has many helpful functions, but they are really easy to use. Acts like a mini engine analyzer. Reads Tach, V, dwell, it works with multi-fire ignition boxes like MSD, and the best of course is the digital advance/retard knob. It has a shock proof casing, and comes in a nice sturdy carrying case. It's fancy but not over the top with options the average mechanic wont use. Im really impressed with mine
[Re: Ramrod39]
#1837140
05/30/15 04:34 AM
05/30/15 04:34 AM
HemiRick
Memphis
The reviews on the 5568 on Amazon have a shocking number of them that failed after 3-4 uses. I was gonna buy one till I saw these 1 star reviews.
