727 trans brake valve bodies #1834841
05/26/15 09:29 PM
05/26/15 09:29 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
727 Valve bodies with trans brake
With so many out there, which one?
Small block 71' Demon with 421CID approximately 600hp, ladder bar with 28x10 tire
Griener
Tranzact
A&A trans
TCI
CRT
THANKS!
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1834857
05/26/15 09:53 PM
05/26/15 09:53 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Forgot about ProTrans in Lancaster, Ca
[img] [/img]
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1834861
05/26/15 09:59 PM
05/26/15 09:59 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I had one from CRT and it worked KILLER!!
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1834872
05/26/15 10:10 PM
05/26/15 10:10 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I think CRT sells the A&A brake..... Or did. I don't think he has one he made himself. I might be wrong, but I don't think so.
I ran the Griner brake for years and liked it. Any of them work good.
Have heard nothing but great stuff about Protrans. If I was to buy one today, would probably try one of his.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1834874
05/26/15 10:11 PM
05/26/15 10:11 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A&A and ProTrans are the same one. I had one and it worked awesome.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 727 trans brake valve bodies [Re: 1967dartgt] #1834875
05/26/15 10:15 PM
05/26/15 10:15 PM
Portage,michigan
Portage,michigan
You sure about that?
A&A is out of the Indy area and owned by Rick Allison. As I said earlier, I think that is what CRT uses.
Pro trans is out in California and does a lot of the Mopars super stock stuff. I thought he made his own stuff?
1.41 best 60 foot
6.56 at 104.17
Re: 727 trans brake valve bodies [Re: B3422W5] #1834882
05/26/15 10:26 PM
05/26/15 10:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Was told buy Rick that him and ProTrans spilt the orders when they get them made. I have had both Pro trans and A&A valve bodies, only difference is pro trans makes the plate gold and Rick leaves his black. Yes crt also gets valve bodies from Rick.
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1834885
05/26/15 10:28 PM
05/26/15 10:28 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have had a 904 from Rick and a all aluminum rollerized 727 from ProTrans.
Re: 727 trans brake valve bodies [Re: 1967dartgt] #1834889
05/26/15 10:31 PM
05/26/15 10:31 PM
Portage,michigan
Portage,michigan
Kinda surprised that is the case. Protrans says on his site his valvebody's are made right on site. Learn something every day..... Interesting.
Edit.... Went back and reread his site...... " inhouse designed and assembled"......... Guess that leaves some wiggle room for " made" there...... Kinda misleading statement , fooled me.... Lol
1.41 best 60 foot
6.56 at 104.17
Re: 727 trans brake valve bodies [Re: B3422W5] #1834900
05/26/15 10:41 PM
05/26/15 10:41 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes Rick and him design the valve body together and each make updates to the process. They are also each assemblies at there own shops but with all the same parts and pieces to help control production costs.
Rick told me they share a lot of hard parts, so they can keep quality up and costs down.
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1835009
05/27/15 01:23 AM
05/27/15 01:23 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Griner was the original and best you could get at one time. The Tranzact is a copy of the Griner with some minor changes. The first TCIs were junk and they started buying from Tranzact, but with Joe's sketchy delivery times, don't know it that is still true. A&A, Pro-Trans and CRT are all the same. Coan has one, but it looks identical to the one TCI now sells.
The fastest ones are fluid exhaust, like the A&A. As of right now, Griner is the KING of the TH400 valve body and supposedly he is incorporating what he learned there on the Mopar brake, but don't know if that has happened yet.
So when it comes right down to it, there may SEEM like a lot of choices, but not really
Monte
Re: 727 trans brake valve bodies [Re: Biginchmopar] #1835044
05/27/15 03:07 AM
05/27/15 03:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You can go to Pro Trans Racing facebook and they have some picts of their work. I sold my Griner LBA trans brake and went with a Pro Trans clean neutral brake this time around. The trans I had it the Mirada was a Lofgren built 727 with a TranzAct brake (non LBA) and that trans worked sooo nice. I'm getting close to pulling the one in the Duster and just having it done.... it just isn't what the Mirada torqueflight was.
