A-Body Race Only Radiator Suggestions. #1833854
05/25/15 01:54 PM
05/25/15 01:54 PM
Richmond, Tx. (Houston)
GTSDave Offline OP
GTSDave  Offline OP
Well,
I dropped a pair of needle nose pliers and ruined my radiator. I was using a 2 row Northern 28 x 19 radiator with a single 16" fan.
The part number on the old Northern radiator was # 9602P. It does not cross to anything, but looks to be identical to the new model # 209672. Northern 209672
Since I have to replace the radiator anyway, I was looking on suggestions on a possible replacement for this one. I find that in hot weather, I am having to run the fan in the staging lanes to cool it down. At the end of a pass I am at 220 or so until I kick on the fan. It cools down fairly quickly, but I would prefer not to have to run the fan if I can avoid it. I run an electric water pump, and use a 16v system with no alternator.
Engine is a low deck 496 that is hard blocked with INDY aluminum heads. A-Body running a 4 speed, so I don't need tranny cooler lines.
What are you using in yours, and are you happy with it?
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1833859
05/25/15 01:58 PM
05/25/15 01:58 PM
Indiana
maxie Offline
maxie  Offline
Indiana
wizard 22 inch radiator
keeps my hemi around 165 degrees all the time
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1833864
05/25/15 02:04 PM
05/25/15 02:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
220 at the end of a pass?..........what in the world temp do you start at?
Monte
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1833920
05/25/15 03:14 PM
05/25/15 03:14 PM
GTSDave Offline OP
GTSDave  Offline OP
Monte,
The last pass I videoed I came out of the water box at about 190. I had to wait for a car in the other lane to be pushed out before I did my burnout. Kicked the fan in but it was for about 1 min before I hit the water box.
Once it heats up it takes a while to cool it down. After the pass I kick on the fan while coasting down and it is usually down to 190 or so by the time I get back to the pits. With the fan and water pump running it is down to 140 or so within a few minutes after I shut the engine down.
Water pump is a CSR.
-Dave
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1833951
05/25/15 03:49 PM
05/25/15 03:49 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why do you choose to race it so hot?
Monte
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834054
05/25/15 06:55 PM
05/25/15 06:55 PM
GTSDave Offline OP
GTSDave  Offline OP
Not a choice Monte,
By the time I drive to the line and get to the burnout box it is pretty hot. I generally try to run it as little as possible before I get to the line. The last race had pretty cool weather, and I still ended up running the fan a bit before I got to the box.
Would prefer to launch at 170 or so.
Thinking about a larger radiator to give me more capacity without having to run the fan. The other thing I have been thinking about is running dual fans with a shroud. I suspect though that I would need some type of trap doors to allow airflow while at speed. Trapping right now near 140. Fan is a 16" in front of the radiator set up as a pusher.
Could be I don't have enough flow with the current water pump.. May have to investigate that as well.
I run the exact same fan and radiator in my 51 Belvedere on the street here in Texas with an iron headed 451 and it stays cool. It is running a stock water pump and it is not hard blocked though.
-Dave
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834087
05/25/15 07:46 PM
05/25/15 07:46 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Are you shutting the fan off during the run?
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834093
05/25/15 07:52 PM
05/25/15 07:52 PM
GTSDave Offline OP
GTSDave  Offline OP
Yes, I shut off the fan just before the burnout box. At the end of the run I kick the fan back on. Once I shut down at the trailer I leave the fan and water pump back on until the gauge goes back down to the bottom (140 deg)
-Dave
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834114
05/25/15 08:14 PM
05/25/15 08:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have been running the Summit 26" but not sure on depth this second and along w/an HHR fan/shroud combo,it keeps my big block pretty cool on the streets and no problems ever at the track. I also wonder as Monte does about the starting temps being that high. I always drive my car around the pits or side road to get it up to about 170-180 then let it heat sink, cool down a bit then get in line but we all know what you mean about not having control over situations. A few on here drive/race w/the combo I mentioned w/great results.
Re: A-Body Race Only Radiator Suggestions. [Re: Thumperdart] #1834133
05/25/15 08:53 PM
05/25/15 08:53 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I stage @ 170. All the tracks around here have a curfew, hence, you have around 10 minutes by the round robin quarters. I choose to strategise, rather than frantically trying to cool down, for the next round
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834146
05/25/15 09:20 PM
05/25/15 09:20 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
U can not push air through a rad. U need a puller fan with a shroud. The shroud helps speed up the air flow through the rad. I use a wizard, a-body with their shroud with 4 8" pullers. Engine temp never goes over 190. It's a little pricey, but it's worth it for my engine.
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834157
05/25/15 09:30 PM
05/25/15 09:30 PM
Colorado Springs, Colorado
Dartthunder340 Offline
I have been using a stock one from an E body, I think. It is okay but I get a little uncomfortable when the temp starts to get to 200* and climbs a little. Been launching at 160*. No shroud, just a 16" puller fan and tranny cooler. I know not much help but I wanted to hear other suggestions also.
Better get inside Ma. Looks like a storm's comin'.
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834183
05/25/15 10:13 PM
05/25/15 10:13 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
As mentioned, that "pusher" fan is a problem, but still I can't imagine why it gets so hot going from the trailer to the lanes. And during the run itself, if it gains 30*, from 190 to 220.........it just shouldn't do that, full of hardblock or not.
Monte
Re: A-Body Race Only Radiator Suggestions. [Re: Monte_Smith] #1834514
05/26/15 01:34 PM
05/26/15 01:34 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Why are you shutting the fan off during the run? To me thats part of the problem if not all of it.
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834539
05/26/15 02:06 PM
05/26/15 02:06 PM
GTSDave Offline OP
GTSDave  Offline OP
Outlaw, I will give it a try and run it, but remember I run a 16v system with no alternator. There are times when we get down into the semi's that I don't have much time to charge the battery.
I have a friend that runs the same setup with the same engine and he has no overheating problems.
Maybe I have a water flow problem. I may need to recheck my pump rotation. That CSR Pump is a bear to prime after I drain the radiator. Not sure if the impeller is unidirectional or not but I will check it.
I have a thermostat with the center section removed to add some restriction, but the inlet on these CSR Pumps is only 3/4" and they list them as 35 to 37gpm. Should be more than enough to cool it as long as I have water flow.
The radiator I am using is a cross flow design.
-Dave
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834682
05/26/15 05:39 PM
05/26/15 05:39 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Have you checked the calibration of your temp gauge?
Nautilus Racing-
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1834705
05/26/15 06:12 PM
05/26/15 06:12 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
What about a dual pass radiator? I plan on upgrading to one in my car once I get the car back together. I have heard they can drop temps up to 20*, a friend of mine runs one in his car, and he says his car never gets over 180*, even with back to back runs.
Re: A-Body Race Only Radiator Suggestions. [Re: OUTLAWSSAA] #1834784
05/26/15 08:04 PM
05/26/15 08:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The rad should have PLENTY of air flow running down the track, fan or not. Plus, if your car won't run 10-12 seconds without getting hot with no fan.........there is another issue.
Monte
Re: A-Body Race Only Radiator Suggestions. [Re: GTSDave] #1835698
05/28/15 12:35 AM
05/28/15 12:35 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I was having problems on the street, this thread helped me alot, I installed a better shroud with the fan properly placed, partially into the shroud opening, so far it's been running 170 degrees, if it creeps to 180 or so in traffic I turn on the 16" pusher electric fan and temp comes back down, I only use it sitting at long traffic lights or traffic jams.
https://board.moparts.org/ubbthreads/ubbt...ing-system.html
