Need opinions on improving my cooling system
#1823066
05/09/15 11:48 PM
05/09/15 11:48 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I run a stroked big block with an aluminum cross-flow radiator, 160 thermostat, plastic flex fan, mechanical high volume water pump, and aluminum shroud.
Because of the motor plate I only have 2.75" of space between the radiator and the water pump pulley so I'm not able to fit an HHR electric fan, and a clutch fan probably won't fit.
This combo has honestly been awesome in the Fall and Spring but today was the true test, 87 degree's here in Akron Ohio with humidity and heavy traffic. This combo survives at speed but the gauge quickly moves up at stop lights. It's never gone over 178 degrees but today it was 220 by the time I got it home, as it climbs a little higher at each stop light.
Should I remove the thermostat and let it flow freely? Is there a better setup that will fit? I normally hack up the core support on A-body cars so the radiator can be moved towards the front of the car more but this car is way too nice to cut-up if I don't have to.
Re: Need opinions on improving my cooling system
[Re: ProSport]
#1823072
05/09/15 11:58 PM
05/09/15 11:58 PM
Posts: 1,845 Tampa
DusterDave
Tampa
The problem is, your fan isn't pulling air though ALL of the radiator fin area. You need to buy or make a SEALED shroud that covers all of the fin area. I'm all for cutting in the name of improvement. Chopping and cutting is part of hot rodding!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: ProSport]
#1823077
05/10/15 12:03 AM
05/10/15 12:03 AM
ProSport
Akron, Ohio
I kinda figured the shroud needs some improvement.
What about my pulleys, the crank pulley and water pump pulley are both about 6 inch diameter, does that make for a good or bad water pump speed? I believe the March pulley kits are about the same size as my pulley's.
[Re: ProSport]
#1823084
05/10/15 12:06 AM
05/10/15 12:06 AM
ProSport
Akron, Ohio
And put what in it's place? That was my question.
[Re: ProSport]
#1823085
05/10/15 12:10 AM
05/10/15 12:10 AM
Posts: 1,845 Tampa
DusterDave
Tampa
I would fix one thing at a time. The lack of an effective shroud is a major contributor to your cooling issue. As pointed out by Pacnorthcuda, replace the flex fan with a solid mechanical fan. Flex fans went out of style 20 years ago!
[Re: DusterDave]
#1823087
05/10/15 12:13 AM
05/10/15 12:13 AM
Posts: 1,532 off the grid
340B5
off the grid
The problem is, your fan isn't pulling air though ALL of the radiator fin area. You need to buy or make a SEALED shroud that covers all of the fin area. I'm all for cutting in the name of improvement. Chopping and cutting is part of hot rodding! ^^^^^^^^^^^^^This. You might as well make a shroud that covers it all because if you buy one of those kits, you'll be making it anyway. Also, make sure the radiator is full to the top to get water in all of the tubes. Let the puke tank take care of the excess/overflow.
Yeah, it's got a smallblock.
[Re: ProSport]
#1823090
05/10/15 12:16 AM
05/10/15 12:16 AM
Posts: 1,845 Tampa
DusterDave
Tampa
You can make a shroud out of aluminum sheet metal, or you can make one out of fiberglass. To make it out of sheet metal, simply get yourself some poster paper (thin cardboard) from Walmart or a craft store, and build a template around that round "shroud" you already have. Once its done, take it out, and transfer it on a sheet of thin aluminum (18 or 20 gage), cut it out, and bend the sides either by hand, or by sandwiching the metal between a couple pieces of square tubing in a vise, and bending over by hand. It can by done on a Saturday, and that's going slow.
[Re: ProSport]
#1823101
05/10/15 12:31 AM
05/10/15 12:31 AM
ProSport
Akron, Ohio
Thanks guys, I actually found the rest of the shroud that came in the kit downstairs, I'll check it out tomorrow to see if it fits everything and add it to my round shroud. I should've done that in the first place.
I'm not a fan of the flex fans either but it is all that would fit in my application. Do you guys know of any steel fixed fans or clutch fans that will work in a 2.75" space? I'll try to google the Bouchillon clutch that you mentioned.
My radiator is up against the core support, no room to move it without hacking the car up.
[Re: ProSport]
#1823141
05/10/15 01:35 AM
05/10/15 01:35 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Your TANKS are against the core support but how thick is the core? I saw about a 15* drop across the board switching from 2x1" cores to 2x1.5" cores. I also use a Derale twin fan setup with shroud. This combo would could keep my old BB A-body at 195* on the street on 100* days in all situations. Also could run flatout on a road course for 20 minutes and just see 220* by the end of that.
Mopar to the bone!!!
[Re: ProSport]
#1823148
05/10/15 01:48 AM
05/10/15 01:48 AM
ProSport
Akron, Ohio
Nice setup 72Swinger, my cores are only 1". I see you had to cut your core support, I think I'm gonna have to do the same if I want to get a clutch fan in there.
[Re: ProSport]
#1823174
05/10/15 02:30 AM
05/10/15 02:30 AM
ProSport
Akron, Ohio
Looks like the Bouchillon clutch is pretty long at 3 5/16". http://bouchillonperformance.com/inc/sdetail/865/898The FC28 seems to be the shortest one but has become very hard to find and expensive. Jaguar 2765 seems to die often since it's built for plastic fans on a Jaguar. The Hayden 2705 is 3.11" and works well with a steel fan from what I've read, this might be the way to go if I cut out my core support and move the radiator, and install a better shroud.
[Re: ProSport]
#1823180
05/10/15 02:44 AM
05/10/15 02:44 AM
Posts: 7,506 Az
Crizila
Az
Should I remove the thermostat and let it flow freely? Is there a better setup that will fit? I normally hack up the core support on A-body cars so the radiator can be moved towards the front of the car more but this car is way too nice to cut-up if I don't have to. That is a crappy fan for pulling air. If you are gonna use a fan, get one like this with a shroud like this.
Fastest 300
[Re: Crizila]
#1823218
05/10/15 08:11 AM
05/10/15 08:11 AM
Posts: 1,629 pa
572charger
pa
i would change the shroud also i had one custom made for my rad i have a 150.00 howe rad and the same fan u have but smaller my 600 + cuin hemi only saw 220 degrees in traffic at woodward !! i have a pusher fan i turn on in traffic only !!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: ProSport]
#1823229
05/10/15 09:13 AM
05/10/15 09:13 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Look at an electric fan setup off of a mid 90s intrepid. It's a dual fan setup and they are pretty cheap. I run one with a small block and an electric water pump, I had the clearance it a little but it works great. You have more room than I do.
68 Barracuda Formula S 340
