This is a 42RE, not an AW4, right? #1831145
05/20/15 10:45 PM
05/20/15 10:45 PM
hooziewhatsit Offline OP
This is in a 93 Grand Cherokee Laredo. Built 5/93. Apparently the early ones have the AW4 transmission, while the later ones have an RE.
The oil pan pictures I found of the AW4 are dramatically different than this, but I'd like an expert opinion before it gets driven a couple hundred miles down to me.
Thanks bow
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831167
05/20/15 11:09 PM
05/20/15 11:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rock auto has pics of the pan gasket, but I had to look under Cherokee for the AW4, it's a rectangle. The 42RE is a 904 style pan, rectangle with one corner cut off.
Don't be the exception.
Re: This is a 42RE, not an AW4, right? [Re: Supercuda] #1831252
05/21/15 12:53 AM
05/21/15 12:53 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
it dont look like a 42re to me,but im fairly certain if it was a 42 it would be a rh in 93,so im guessing its a aw4
my ladder of success is missing some rungs
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831273
05/21/15 01:44 AM
05/21/15 01:44 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
42RH
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831275
05/21/15 01:49 AM
05/21/15 01:49 AM
Oh yea, it has the straight 6, not the v8.
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831453
05/21/15 02:36 PM
05/21/15 02:36 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Its a 42.
Carl Kessel
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831688
05/21/15 08:25 PM
05/21/15 08:25 PM
To complicate things, I need it to be an RE. If it's an RH, it's no good to me.
Wikipedia says (laugh2) that the only RHs in that year came behind a 5.2/v8.
Sooo... if it is a 42, I'm assuming it must be an RE.
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831691
05/21/15 08:27 PM
05/21/15 08:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
RH
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1831769
05/21/15 10:23 PM
05/21/15 10:23 PM
So my dad just crawled under it, and says he can feel 6 or 7 wires (there might be one more, lol), so it must be an RE.
I'll verify once it gets down here.
Thanks for the input.
Re: This is a 42RE, not an AW4, right? [Re: hooziewhatsit] #1832167
05/22/15 02:02 PM
05/22/15 02:02 PM
A727Tflite Offline
A727Tflite  Offline
Most all 4.0 93.5 Grand Cherokees had 42RE. We only built a small number of AW4 in 93 behind the 4.0 - a very small number and at vehicle launch. Early in the Model Year.
