Still no aftermarket RB/LD Mopar steel blocks I see #1824422
05/11/15 08:14 PM
05/11/15 08:14 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
What a disappointment.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1826829
05/14/15 08:13 PM
05/14/15 08:13 PM
dogdays Offline
dogdays  Offline
There haven't ever been any steel blocks, except some industrial engines. They're either cast iron, aluminum or compacted graphite (special high strength cast iron). The same for cylinder heads.
Just a pet peeve of mine.
It may be time to start talking about fabricating some steel blocks, though. Nothing says the block has to be a casting. And steel is stiffer than grey cast iron or aluminum. Put it together by welding.
Why not?
R.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1826855
05/14/15 08:50 PM
05/14/15 08:50 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Still no updates on Koleno's facebook since Sept 29th saying they were trying to get back in production down
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1826877
05/14/15 09:26 PM
05/14/15 09:26 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Indy has aluminum lol
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: FastmOp] #1826908
05/14/15 10:04 PM
05/14/15 10:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a couple I have been thinking of moving wave
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829358
05/18/15 06:00 PM
05/18/15 06:00 PM
AndyF Offline
AndyF  Offline
I heard that there are some new Mopar blocks in the process of being tested. I talked to a guy who said he was supplying parts for the tests. So maybe something is moving along in the supply chain?
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829359
05/18/15 06:01 PM
05/18/15 06:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
There is a low deck Indy block in the raceparts section.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829371
05/18/15 06:22 PM
05/18/15 06:22 PM
Salt Lake City
Salt Lake City
I would really like to have a raised cam deal, but may have to settle for brand X.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829451
05/18/15 07:53 PM
05/18/15 07:53 PM
AndyF Offline
AndyF  Offline
Call Stanton and see if he'll tell you anything. I heard that the first batch of blocks are being tested with 4.50 cranks so maybe there will be a raised cam option.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829461
05/18/15 08:20 PM
05/18/15 08:20 PM
Salt Lake City
Salt Lake City
Are you talking about the Nascar guy in Tenn?
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1829983
05/19/15 12:52 PM
05/19/15 12:52 PM
Salt Lake City
Salt Lake City
Talked to Gary, no wedges. Hemis only and it will still be a while.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1830234
05/19/15 06:51 PM
05/19/15 06:51 PM
AndyF Offline
AndyF  Offline
Now you know more than most
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1830313
05/19/15 08:50 PM
05/19/15 08:50 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looking for a block myself. Bob George says that none are available. I am getting tired of using stock blocks that crack after a few years use.
If you like drag racing, support your local track.
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: Al_Alguire] #1830612
05/20/15 08:15 AM
05/20/15 08:15 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I seen that listing in the race part section, it states that it's an old style Indy block...........what's the difference between the old and new? shruggy
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: camastomcat] #1830692
05/20/15 11:47 AM
05/20/15 11:47 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There are a few out there that people bought over the years,we have a few but are dedicated to current customers.The problem with what is out there no one knows the quality and batches they came from,some are great,some can't be bored much and some are junk.The bad part is because of the shortage the prices are over the top.We recently have seen a 10% increase for blocks from one of our suppliers.Buyers beware.
I just looked back in our archives and found my paper work on the last large order of Chrysler hemi and wedge blocks from 2005.I was paying $2240 per block.These were Siamese,mega and street blocks.On 4 or more blocks I was paying $1900 per.Go figure shruggy
Re: Still no aftermarket RB/LD Mopar steel blocks I see [Re: racerx] #1830694
05/20/15 11:53 AM
05/20/15 11:53 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There has been a few revisions,older block have press in core plugs,no or less valley ribs.The new blocks have more strength ribs,screw in plugs and oiling modifications.
