AFB or AVS Carb identification... #1825554
05/13/15 10:58 AM
05/13/15 10:58 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I picked up this carb a while back...the guy had a lot of 67-68 440 parts. Any idea what this is from...year...engine...model?
Thx all... thumbs
...FAFO...
Re: AFB or AVS Carb identification... [Re: skicker] #1825560
05/13/15 11:01 AM
05/13/15 11:01 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
These are the numbers on the RF of the baseplate... shruggy
Maybe D8 440 1S?
...FAFO...
Re: AFB or AVS Carb identification... [Re: skicker] #1825568
05/13/15 11:06 AM
05/13/15 11:06 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1968 383 Automatic, D = April, 8 = 1968 assembly date
Re: AFB or AVS Carb identification... [Re: ScottSmith_Harms] #1825573
05/13/15 11:15 AM
05/13/15 11:15 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Thx Scott!! One of these days I'm going to have to learn all of that part of it... thumbs
...FAFO...
Re: AFB or AVS Carb identification... [Re: skicker] #1825578
05/13/15 11:21 AM
05/13/15 11:21 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Its an AVS. You can tell from the dimpled covers over the metering rods. AVS's used dimpled because of the three step metering rods. AFB's used flat due to two step rods. 3 step rods are longer than 2's.
Carl Kessel
Re: AFB or AVS Carb identification... [Re: skicker] #1825617
05/13/15 11:57 AM
05/13/15 11:57 AM
I was thinking that Ma stopped venting the bowl to the atmosphere in the 68 + model years for emission regs (you see the bowl vent on top with the black round neoprene cover) but the numbers dont lie. Yes convert it eddy 2 step rods/shorter pri jets & I'd start with the cruise step several tho smaller than what the 3 step rod has now. Fill the metering rod caps with JBweld then cover em with scotch tape & invert em so the mud settles flat on the bottom & let em set up like that for a day or so
Re: AFB or AVS Carb identification... [Re: CKessel] #1825622
05/13/15 12:02 PM
05/13/15 12:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Most Chrysler OEM AFBs also used three-step rods and the raised covers.
The air horn is the obvious giveaway with the exposed air valve secondary (A.V.S.)
Re: AFB or AVS Carb identification... [Re: Jim_Lusk] #1825757
05/13/15 02:08 PM
05/13/15 02:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
Some Chrysler OEM AFBs also used three-step rods and the raised covers.CORRECTED whistling
scope iagree
Re: AFB or AVS Carb identification... [Re: skicker] #1825818
05/13/15 03:46 PM
05/13/15 03:46 PM
Tennessee
moparjunkyard Offline
Tennessee
Also note that this is a 625 CFM carb and the adjusting screw is Left Hand threaded. Note also that it is for a High Performance Automatic Car. If it was a 750 CFM AVS, All 4 of the butterflies would be the same size. That is the easiest way to just flip over an AVS and know if its 625 or 750 CFM. As you see here the primaries are smaller. Most 440 AVS carbs are 750 CFM. 68 HP 4-Speed carb would be number 4426S Hope this helps even more.
1968 A-STOCK AUTOMATIC/426 Hemi Super Bee Numbers Matching
Re: AFB or AVS Carb identification... [Re: moparjunkyard] #1825836
05/13/15 04:10 PM
05/13/15 04:10 PM
good stuff!
Re: AFB or AVS Carb identification... [Re: skicker] #1826319
05/14/15 12:23 AM
05/14/15 12:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
AVS also all use the spring loaded secondary air valve right at the top of the carb. AFB's used a weighted air valve without the spring tension and it was down low in the secondaries where you could not see it just glancing at the carb. All the AVS had the spring loaded air valve right at the top like that one which tells us AVS stood for "Air valve Secondary" or thats what I was always told. The rubber nipple on the link coming off the acell pump arm is for the external bowl vent which would be open at normal idle and would close as soon as the throttle was stepped on to make it a balanced carb using the internal air horn bowl vent when driving along. Ron
Re: AFB or AVS Carb identification... [Re: 383man] #1826622
05/14/15 03:04 PM
05/14/15 03:04 PM
dogdays Offline
dogdays  Offline
There's also an "AVS" cast into the side of the carb body, but everything you really need to know comes from the number stamped into the front passenger side foot. In this case it's a 4401.
The number lists will tell you the rest.
R.
Re: AFB or AVS Carb identification... [Re: skicker] #1826910
05/14/15 10:05 PM
05/14/15 10:05 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Don't suppose you're planning to crack that thing open any time soon? hint hint wink
I'm trying to put my AVS back together and am not quite if the float clips that came in my kit are the right ones. Love a look inside that thing if you get curious and open it up. Here's a link to my post on the topic showing what I need pics of.
https://board.moparts.org/ubbthreads/ubbt...ght.html#UNREAD
Few tips in the event you do take it apart.
Take the metering rods covers off and the rod/piston assys out first so you don't bend the rods putting the top back on afterwards. Top goes back on THEN the metering rod/vacuum piston assys drop back in after that. And snap a few pics of the linkages outside b4 u disassemble it and then the inside b4 you start taking the guts out. Its much easier to put back together that way. (as in I SHOULD HAVE done that...LOL)
Thanks,
Re: AFB or AVS Carb identification... [Re: Dave440] #1826984
05/14/15 11:49 PM
05/14/15 11:49 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
No real plans for it now. It was with a lot of parts I bought back in the fall. It ended up in the toolbox on my truck and I completely forgot all that stuff was even there. I never know what I'm getting into next so I'll probably keep it. thumbs
...FAFO...
Re: AFB or AVS Carb identification... [Re: skicker] #1826992
05/15/15 12:09 AM
05/15/15 12:09 AM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Thanks anyway. I'm sure someone will come up with a pic...or I'll just pinch the clips a bit and hope it works out.
Here's a link you might like. Full list of Carter carbs and parts with exploded views. Everything xcept those clips of course...they don't even appear in my paper instructions! Guess there's no Chinese word for float clip...LOL!!!
It's a PDF file so it takes a minute to load.
Carter carbs - exploded views-parts list - WALKER
Re: AFB or AVS Carb identification... [Re: Dave440] #1827007
05/15/15 12:31 AM
05/15/15 12:31 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Don't worry about the clips,it will work without them,in 90% of the carbs I get for restoration the clips are long gone. twocents
Re: AFB or AVS Carb identification... [Re: skicker] #1827553
05/15/15 11:11 PM
05/15/15 11:11 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Can I jump in with one please? I have am AVS I got in a group of parts a long time ago. Best I can tell it says L0 4966S. Looks to be 625 cfm according to the post above. So would that be December of 1970 date code?
Re: AFB or AVS Carb identification... [Re: tmef] #1827616
05/16/15 12:51 AM
05/16/15 12:51 AM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
4966s is 1971 440 auto non hp
625cfm is a good guess. It's definitely the smaller of the 2 versions.
As Moparjunkyard stated on p1 of this thread, the AVS with equal butterflies on all 4 corners is approx 750cfm but numbers were never officially released.
Re: AFB or AVS Carb identification... [Re: Dave440] #1827626
05/16/15 01:12 AM
05/16/15 01:12 AM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Thanks for the info. This one does have smaller primaries.
