ThermoQuad: Need De-Smog Modification Procedures #1825801
05/13/15 03:25 PM
05/13/15 03:25 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
Carter Thermoquad off a '79 Dodge Diplomat 318. The carb P/N is 9245S.
Does anyone know What modifications need to be made for use on a non-smog equipment engine?
Re: '78-'84 Thermoquad, Smog Removal Modifications? [Re: D_C] #1825852
05/13/15 04:28 PM
05/13/15 04:28 PM
D_C Offline OP
D_C  Offline OP
I saw this earlier post. Wondered if there was any better advice about what to remove, drill, fill in, etc?
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/5018785/site_id/1
Re: '78-'84 Thermoquad, Smog Removal Modifications? [Re: D_C] #1826434
05/14/15 05:32 AM
05/14/15 05:32 AM
D_C Offline OP
D_C  Offline OP
I heard the DemonSizzler went out of business. Wondered if anyone knows procedures for modifying the Top and Base plates?
Re: '78-'84 Thermoquad, Smog Removal Modifications? [Re: D_C] #1826621
05/14/15 03:01 PM
05/14/15 03:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm not going to be of much help, but I recall reading from Demonsizzler back in the day that the internal bleeds and feed passages were of different diameters on the smogger versus non smogger thermoquads and that there was more to it than just plugging certain passages. Whether that's true or part of the sales pitch I don't know.
Have you tried looking into what a pre-smog thermoquad is worth? IIRC number starts with a 6 instead of a 9. I have a pre-smog 440 thermoquad and ran it on my 440 as a daily driver for years. Ran great!
Re: '78-'84 Thermoquad, Smog Removal Modifications? [Re: D_C] #1826650
05/14/15 03:38 PM
05/14/15 03:38 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
That's really too bad, he should write a book I would buy the first one or 2.
Re: '78-'84 Thermoquad, Smog Removal Modifications? [Re: D_C] #1826700
05/14/15 05:03 PM
05/14/15 05:03 PM
D_C Offline OP
D_C  Offline OP
Thanks for the replies. Every bit of information helps. Thanks Again.
