3 speed wiper conversion #1825120
05/12/15 06:30 PM
05/12/15 06:30 PM
Ohio
jimm69 Offline OP
jimm69  Offline OP
Ohio
I wanted to convert my 69 Roadrunner to air grabber setup so I purchased a 3 speed wiper motor to swap out my 2 speed unit. I purchased a new wiring harness for under hood and everything plugged in fine. I was told the dash switch would just plug into the existing wiring but the terminals are different on the back of the switches. Did I just purchase the incorrect switch or did I get incorrect information on the interchange? Any suggestions?
Re: 3 speed wiper conversion [Re: jimm69] #1825182
05/12/15 08:21 PM
05/12/15 08:21 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
If your plugging a 3 speed switch into a 2 speed wiper dash harness its not going to work. Different plug configuration and the 3 speed has a resistance cable built into the dash harness. Do you have the FSM?
Edit: this is the Rallye Gauge 3 speed connection. 2 of the single leads go to the Washer Pump switch.
Re: 3 speed wiper conversion [Re: jimm69] #1825214
05/12/15 08:55 PM
05/12/15 08:55 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I have not done the conversion but have looked into it. According to the thread below you are correct, the switch should plug in.
The 3spd switch# is 2864014. Is that what you have?
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/8119820/site_id/1#import
Re: 3 speed wiper conversion [Re: moparfan53] #1825219
05/12/15 09:05 PM
05/12/15 09:05 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
So U really think a 2spd switch will operate a 3spd motor,that's like saying a 3spd shifter will work a 4spd.
Re: 3 speed wiper conversion [Re: jimm69] #1825225
05/12/15 09:27 PM
05/12/15 09:27 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I converted mine over several years ago. I needed just a three speed switch. The harness plugged right in.
1968 Plymouth Road Runner 383 4 speed
Re: 3 speed wiper conversion [Re: dobie] #1825399
05/13/15 01:09 AM
05/13/15 01:09 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct, the 68-70 B Body 2 to 3 spd wiper conversion only requires the correct 3 spd switch, 3 spd motor with correct 3 spd motor arm, the wiper linkage is the same under the dash, the dash harness has provisions for either switch...
