drill speed when performing oil mods #1823160
05/10/15 02:03 AM
05/10/15 02:03 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
what drill speed works best when doing oil mods on cast iron block? don't want to break any drill bits.
Re: drill speed when performing oil mods [Re: mopar dave] #1823188
05/10/15 03:16 AM
05/10/15 03:16 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I always use a fast speed with little pressure on cast iron but never did the oil mods to a block.
Re: drill speed when performing oil mods [Re: mopar dave] #1823191
05/10/15 03:28 AM
05/10/15 03:28 AM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
go slow, dont use oil, drill pilot hole, then one size smaller than final size, then final size. the key is lots of straight steady pressure
Re: drill speed when performing oil mods [Re: mopar dave] #1823279
05/10/15 10:47 AM
05/10/15 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dull down the bit slightly.. that way it wont try to bite..
when the bite bites is when they break.. also.. iron cuts easy
thats why they tend to bite
wave
Re: drill speed when performing oil mods [Re: MR_P_BODY] #1823316
05/10/15 11:41 AM
05/10/15 11:41 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks guys. slow speed and easy steady pressure. got it.
Re: drill speed when performing oil mods [Re: mopar dave] #1823319
05/10/15 11:42 AM
05/10/15 11:42 AM
Mt Morris Michigan
Mt Morris Michigan
also, don't know what size the main feeds are, but will be starting with a 1/4" bit then to 9/32" final size.
Re: drill speed when performing oil mods [Re: mopar dave] #1823749
05/10/15 10:52 PM
05/10/15 10:52 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
9/32" drill and some WD-40. Don't know the rpm, just use what felt right. It drills pretty easy.
Re: drill speed when performing oil mods [Re: BSB67] #1823812
05/10/15 11:33 PM
05/10/15 11:33 PM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
if you use oil or lube, it tends to make the cuttings into lapping compound and makes the hole oversized, do it dry if the hole is dimension critical
Re: drill speed when performing oil mods [Re: mopar dave] #1824042
05/11/15 11:29 AM
05/11/15 11:29 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Back in the '70's we didn't have a variable speed drill. A Black and Decker and a long bit that I bought at a hardware store did just fine - no pilot holes, no lube, etc.. Two years ago I used the same bit in a new B&D drill with no pilot holes and no lube and again, no problems. Keep it simple! One thing I would suggest ... a low-power cordless will stop before the bit snaps if it jams. Use a big powerful drill and the potential to snap the bit just increased!
I imagine I could ten blocks in the time it took to make that guide plate !!!
Re: drill speed when performing oil mods [Re: mopar dave] #1824049
05/11/15 11:45 AM
05/11/15 11:45 AM
Mt Morris Michigan
Mt Morris Michigan
ok, good points. I will be careful with drill speed and no lube.
Re: drill speed when performing oil mods [Re: mopar dave] #1824054
05/11/15 11:59 AM
05/11/15 11:59 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Don't make a bigger project out of this than it really is. I drilled mine and shoved 2 pieces of house water line in it, peened it with a rounded of scrap lifter (then I found the old peening tool that came in my Ed Hamburgers kit I bought years ago), drill your oiling hoes, enlarge the ones you want bigger, drill and tap the front to block off the other side, and wash,wash,wash to flush everything out. I may have skipped a step or two but the book walks you thru nicely and I still refer to it every time I do one as one missed step could get VERY expensive. Just DON"T forget to drill the holes thru the tube after you have it installed. Trial fit your lifters to make sure the tube has been peened sufficiently.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: drill speed when performing oil mods [Re: pittsburghracer] #1824080
05/11/15 12:20 PM
05/11/15 12:20 PM
Mt Morris Michigan
Mt Morris Michigan
going to block drivers galley at 1 main, but will not be tubing pass. side. opening up main galleys as well as the 1/2" galleys. that's it.
