Alum main caps for RB #1823107
05/10/15 12:36 AM
05/10/15 12:36 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone that uses alum main caps in a RB, can you you tell me who to purchace them from and how involved is it to install them. Is this something that a good machine shop can do?
Thanks,
Brian
Re: Alum main caps for RB [Re: '72CudaRacer] #1823138
05/10/15 01:34 AM
05/10/15 01:34 AM
I bought a set of the 440 Source aluminum main caps and ARP main studs from them, my local automotive and industrail machine shop(Southward in Eugene OR) did the fitting and align hone on the 440 block my customer provided, they made the comment that they went on fine and machined well. They where inmpressed enough to ask where I got them from work I'm assuming that they will buy them direct for future builds they do from now on up
Re: Alum main caps for RB [Re: '72CudaRacer] #1823147
05/10/15 01:43 AM
05/10/15 01:43 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I bought the BCR aluminum caps along with the Girdle and main studs. As stated above the engine will have to be aligned honed to fit the caps. Any engine machine shop with the equipment can do the work. With the girdle the block pan rail has to be machined flat along with the caps .
Re: Alum main caps for RB [Re: rowin4] #1823158
05/10/15 02:00 AM
05/10/15 02:00 AM
Mooresburg, Tn
Mooresburg, Tn
What about fitting the new caps to the block registers? Any machine work required for that or do they fit out of the box? I realize that it has to be align honed after installation.
Any options other than BRC and 440 source?
Thanks,
Brian
Re: Alum main caps for RB [Re: '72CudaRacer] #1823159
05/10/15 02:03 AM
05/10/15 02:03 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I think Best Machine offers caps too
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Alum main caps for RB [Re: pittsburghracer] #1823216
05/10/15 06:05 AM
05/10/15 06:05 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Best Machine no longer sells the main caps for rb 440. He laughed about not knowing how to turn the advertisment off on the Moparts webpage as I spoke with them on Wednesday. Ordered Mancini caps so I'll see how things go for the new motor going together. wrench
Re: Alum main caps for RB [Re: '72CudaRacer] #1823221
05/10/15 08:37 AM
05/10/15 08:37 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we make the bcr caps and girdle kits and ours don't need any register modification and should tap down in with a slight interference fit, just like factory caps.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Alum main caps for RB [Re: Jerry] #1823325
05/10/15 11:48 AM
05/10/15 11:48 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Bought some from Mancinni a few years ago, nice quality stuff. You still want to have it line bored to make sure everything is perfect.
Re: Alum main caps for RB [Re: '72CudaRacer] #1823328
05/10/15 11:52 AM
05/10/15 11:52 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Most all of the caps I've seen, come for the b-engine, and then require extra machining to get to the RB size main.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Alum main caps for RB [Re: MoparBilly] #1823336
05/10/15 12:05 PM
05/10/15 12:05 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
And don't forget about the thrust. That surface will need to be addressed as well. I have used both 440 and BCR caps. Make sure you get 12-pt nuts for the studs. Hex stuff is really tight.
Re: Alum main caps for RB [Re: '72CudaRacer] #1823343
05/10/15 12:19 PM
05/10/15 12:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I was told they need to be align bored, not align honed, during installation. Align boring keeps the radius consistent, but align honing can change the radius from the crank centerline due to the differences how the hone removes material from the harder iron (block) side and the softer cap (alum) side.
FWIW, I like the BCRs, and didn't know Best stopped making theirs. I know one person who broke a Best cap, but don't know all the details to indicate where the issue was.
Re: Alum main caps for RB [Re: '72CudaRacer] #1823756
05/10/15 10:56 PM
05/10/15 10:56 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yes the caps need to be align bored and yes they come in the 383/400 journal size. its not a problem to remove extra material. on most engine the #4 cap has the most stress due to its position in the firing order. that cap cracks. we use 6061 aluminum that's made in the USA for our caps. these are plenty strong and more ductile than a 7075 aluminum counterpart. feel free to call with any questions we're always available to get you some answers. sometimes out in the shop and don't hear the phone ring. so leave a message.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
