Re: Alum main caps for RB
[Re: '72CudaRacer]
#1823147
05/10/15 01:43 AM
05/10/15 01:43 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I bought the BCR aluminum caps along with the Girdle and main studs. As stated above the engine will have to be aligned honed to fit the caps. Any engine machine shop with the equipment can do the work. With the girdle the block pan rail has to be machined flat along with the caps .
[Re: rowin4]
#1823158
05/10/15 02:00 AM
05/10/15 02:00 AM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
What about fitting the new caps to the block registers? Any machine work required for that or do they fit out of the box? I realize that it has to be align honed after installation. Any options other than BRC and 440 source?
Thanks, Brian
[Re: '72CudaRacer]
#1823159
05/10/15 02:03 AM
05/10/15 02:03 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think Best Machine offers caps too
[Re: '72CudaRacer]
#1823328
05/10/15 11:52 AM
05/10/15 11:52 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Most all of the caps I've seen, come for the b-engine, and then require extra machining to get to the RB size main.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1823336
05/10/15 12:05 PM
05/10/15 12:05 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
And don't forget about the thrust. That surface will need to be addressed as well. I have used both 440 and BCR caps. Make sure you get 12-pt nuts for the studs. Hex stuff is really tight.
