'65 torqueflite #1819702
05/05/15 10:29 PM
05/05/15 10:29 PM
usa
lewtot184 Offline OP
usa
anybody know where to buy the kick down shaft seal?
Re: '65 torqueflite [Re: lewtot184] #1819712
05/05/15 10:38 PM
05/05/15 10:38 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
This guy knows those old Torqueflites and sells parts on e-bay all over the world.
Pat Blais.
eBay store T'Flite Patty's Shop Mart
tflitepatty@comcast.net
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: '65 torqueflite [Re: Polarapete] #1819729
05/05/15 10:49 PM
05/05/15 10:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try john Cope.All he does is Mopar trannys CRT is a sponsor here.Rocky
Chrysler Firepower
Re: '65 torqueflite [Re: lewtot184] #1819863
05/06/15 12:39 AM
05/06/15 12:39 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
It is the same seal that is used on the later model that also seals the kickdown shaft. On the later models it is not in the case but in the valve body. Remove the circlip and washer from the kickdown shaft and the seal is below the washer.
Re: '65 torqueflite [Re: PC-CHARGER] #1819895
05/06/15 01:07 AM
05/06/15 01:07 AM
if it is the seal I am thinking of it goes in the case (from the top) then the VB shaft goes up thru it from underneath. not sure about early/late but on the later ones the 904/727 are the same. it looks like a miniature 8&3/4 end seal (the big one you drive in). I have a baggie of 20 of em & I'll see if I can find em tomorrow & take a pic & I would send you one.
Re: '65 torqueflite [Re: lewtot184] #1820032
05/06/15 10:37 AM
05/06/15 10:37 AM
usa
usa
the seal on the early cable trans is different. i've bought from pat blais before. just looking to see if there was something out there at the parts stores. thanks everybody.
Re: '65 torqueflite [Re: lewtot184] #1820211
05/06/15 01:33 PM
05/06/15 01:33 PM
dogdays Offline
dogdays  Offline
Seals, like rolling element bearings and O-rings, are standardized.
Given the hole diameter, the shaft diameter and the width, it should be possible to buy from an industrial supplier, although it may be sold in lot sizes of 20 or 50 or whatever.
R.
Re: '65 torqueflite [Re: lewtot184] #1820238
05/06/15 02:31 PM
05/06/15 02:31 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
the seal should be available from most amy transmission shop as it comes in all 727. 904, 500, 518 or 4X series gasket kits. It is the same one used on the valve body as shown in these pictures.
Re: '65 torqueflite [Re: lewtot184] #1820261
05/06/15 03:15 PM
05/06/15 03:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope. Same seal from '60 until the end of production.
Re: '65 torqueflite [Re: John_Kunkel] #1820306
05/06/15 04:06 PM
05/06/15 04:06 PM
usa
usa
my '69 service manual is showing a larger seal,....? i know i've been thru this before but must have slept too much since then. rock auto is showing a larger seal than what i have, assuming i'm looking at the right seal.
i'm tring to get the pat blais ebay site up but so far no luck. he sells a re-seal kit and i need a kick down lever too.
Re: '65 torqueflite [Re: lewtot184] #1820319
05/06/15 04:29 PM
05/06/15 04:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '66-on metal-clad shift shaft seal in the case is larger, the subject all-rubber TP shaft seal was the same from day one.
http://www.ebay.com/itm/like/161572202143?lpid=82&chn=ps
Re: '65 torqueflite [Re: lewtot184] #1820356
05/06/15 05:21 PM
05/06/15 05:21 PM
Andrewh Offline
Andrewh  Offline
so the inner seal is the same. the outer seal is different?
Re: '65 torqueflite [Re: Andrewh] #1820373
05/06/15 05:46 PM
05/06/15 05:46 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Exactly. The cable shift units only had the throttle pressure shaft that came through the case and used the seal. The shift cable entered below and forward and used an O ring seal. As John said, in 1966 when the linkage type shifter was introduced, there were now two shafts that come through the case. The shifter shaft is larger and uses a metal backed seal that is pressed into the case while the throttle pressure shaft now comes through the center of the shifter shaft but uses the same seal that used to be in the case of the previous cable shift units.
Re: '65 torqueflite [Re: PC-CHARGER] #1820405
05/06/15 06:31 PM
05/06/15 06:31 PM
usa
usa
that explains it.
