Re: '65 torqueflite
[Re: lewtot184]
#1819712
05/05/15 10:38 PM
05/05/15 10:38 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
This guy knows those old Torqueflites and sells parts on e-bay all over the world. Pat Blais.
eBay store T'Flite Patty's Shop Mart
tflitepatty@comcast.net
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: '65 torqueflite
[Re: Polarapete]
#1819729
05/05/15 10:49 PM
05/05/15 10:49 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Try john Cope.All he does is Mopar trannys CRT is a sponsor here.Rocky
Chrysler Firepower
Re: '65 torqueflite
[Re: PC-CHARGER]
#1819895
05/06/15 01:07 AM
05/06/15 01:07 AM
RapidRobert
if it is the seal I am thinking of it goes in the case (from the top) then the VB shaft goes up thru it from underneath. not sure about early/late but on the later ones the 904/727 are the same. it looks like a miniature 8&3/4 end seal (the big one you drive in). I have a baggie of 20 of em & I'll see if I can find em tomorrow & take a pic & I would send you one.
Re: '65 torqueflite
[Re: lewtot184]
#1820261
05/06/15 03:15 PM
05/06/15 03:15 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
the seal on the early cable trans is different. Nope. Same seal from '60 until the end of production.
Re: '65 torqueflite
[Re: John_Kunkel]
#1820306
05/06/15 04:06 PM
05/06/15 04:06 PM
Posts: 3,916 usa
lewtot184
usa
the seal on the early cable trans is different. Nope. Same seal from '60 until the end of production. my '69 service manual is showing a larger seal,....? i know i've been thru this before but must have slept too much since then. rock auto is showing a larger seal than what i have, assuming i'm looking at the right seal. i'm tring to get the pat blais ebay site up but so far no luck. he sells a re-seal kit and i need a kick down lever too.
Re: '65 torqueflite
[Re: PC-CHARGER]
#1820405
05/06/15 06:31 PM
05/06/15 06:31 PM
Posts: 3,916 usa
lewtot184
usa
Exactly. The cable shift units only had the throttle pressure shaft that came through the case and used the seal. The shift cable entered below and forward and used an O ring seal. As John said, in 1966 when the linkage type shifter was introduced, there were now two shafts that come through the case. The shifter shaft is larger and uses a metal backed seal that is pressed into the case while the throttle pressure shaft now comes through the center of the shifter shaft but uses the same seal that used to be in the case of the previous cable shift units.
that explains it.
