Re: Rotten egg smell in race car
[Re: correctdirection]
#1819865
05/06/15 12:39 AM
05/06/15 12:39 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
It is the battery...When batteries "cook" they produce a very sulfuric odor. If you have an alternator it is over charging the battery! Possibly the odor was lingering. Put a voltmeter on the car while running with alternator hooked up and see what you get. My bet is it is the alternator/voltage reg something is telling it to put out to much voltage, cold be a connection to the batter as well.
[Re: Al_Alguire]
#1820055
05/06/15 11:07 AM
05/06/15 11:07 AM
Posts: 176 Sterling Heights, MI
John_T_Brown
It is the battery...When batteries "cook" they produce a very sulfuric odor. If you have an alternator it is over charging the battery! Possibly the odor was lingering. Put a voltmeter on the car while running with alternator hooked up and see what you get. My bet is it is the alternator/voltage reg something is telling it to put out to much voltage, cold be a connection to the batter as well. +1
If it ain't broke fix it anyway!
#1820442
05/06/15 07:00 PM
05/06/15 07:00 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I had a really strange smell in my car a few years back. It turned out to be my Holly Blue fuel pump eating itself. Maybe take a quick sniff of your pump!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
#1820461
05/06/15 07:23 PM
05/06/15 07:23 PM
Al_Alguire
Las Vegas
You could also examine the battery as well. Look for signs of it swelling, if it has then it has been overcharged.
[Re: tubtar]
#1820707
05/07/15 12:04 AM
05/07/15 12:04 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
White castle burgers and cheap beer the night before ? That's what I was thinking. ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif) What 'should' the voltmeter read? I have a Toyota Denso alternator and it is always at 14 volts, someone told me it shouldn't be that high at all times but I haven't had any problems and it's the best charging system I've ever owned, battery never struggles or runs low like every setup I've had in the past.
[Re: cudaman1969]
#1820832
05/07/15 02:57 AM
05/07/15 02:57 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
This.^^^^^^^^ If your 60's have slowed and mph is down, it would be a virtual guarantee. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Chris. .
