Re: Old theories die hard in the mopar world...
[Re: Hot 340]
#1819688
05/05/15 10:09 PM
05/05/15 10:09 PM
Posts: 7,506 Az
Crizila
Az
The other day I heard the one where you need to run two points higher compression with aluminum to make the same power as iron. It was like 1992 all over again. Don't know about the 2 points higher thing ( sounds a little - extravagant, but all else being equal, aluminum dissipates the heat faster than cast iron and HP is all about making heat - so ......... you can run more lead with aluminum ( if your motor like it - mine does ) and still stay out of detonation.
Fastest 300
[Re: dustergirl340]
#1819816
05/06/15 12:03 AM
05/06/15 12:03 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Still haven't had anyone snatch that gosh darned $20 bill off the dash yet...of course my car does make 1,200 HP on Yellowbullet. Fixed.
[Re: slantzilla]
#1819828
05/06/15 12:14 AM
05/06/15 12:14 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
A guy told me that his buddy's car was fast it had a 4 bolt main 350 with double hump heads.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
