pics of my bearings for the 408
#1813850
04/28/15 01:32 PM
04/28/15 01:32 PM
Posts: 8,046 Mt Morris Michigan
mopar dave
Mt Morris Michigan
the bearings are set up L to R #1 main thru #5 and same on rods L to R. uppers are at top and lowers on bottom. they have about 40-50 passes and 1500-2000 miles i'm guessing. what do you think? did they get enough oil and especially #1 main and rod?
Re: pics of my bearings for the 408
[Re: mopar dave]
#1813952
04/28/15 03:51 PM
04/28/15 03:51 PM
Posts: 43,321 Bend,OR USA
Cab_Burge
The rod bearing look good to me ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I would check the actual run out on the # 2 and #4 crankshaft mains to see what is causing those two main bearings to look like they do ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I've seen more than one SB crankshaft have run out on the #2 main ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Let us know what you find out ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: mopar dave]
#1814440
04/29/15 08:53 AM
04/29/15 08:53 AM
Challenger 1
Cincinnati, Ohio
the upper rod bearings look to be more worn in the center while the lowers appear to be more worn on the outside edges. i'll have to mic the crank when I get time. The upper rod bearings should be the only ones showing wear, the lowers are just along for the ride. Hows the rod bearings crush? I bet not good?
[Re: mopar dave]
#1814553
04/29/15 01:28 PM
04/29/15 01:28 PM
BradH
[code][/code] the bearings are set up L to R #1 main thru #5 and same on rods L to R. uppers are at top and lowers on bottom. they have about 40-50 passes and 1500-2000 miles i'm guessing. what do you think? did they get enough oil and especially #1 main and rod? If my bearings looked like that after the amount of use you described above, I'd be concerned about the source of the problem. The rods look "so-so" at best, and a couple of those crank bearings just plain look bad, maybe like temporay oil starvation. Not sure I can add any more to what others have said. I, too, suspect the crank has issues, but would want to verify there are no obstructions in the oiling passages, etc.
[Re: mopar dave]
#1814598
04/29/15 03:04 PM
04/29/15 03:04 PM
dogdays
I don't understand that last comment. ANY positive displacement pump oils by rpm. The flow out of the pump is directly proportional to the pump speed, which is directly proportional to crankshaft speed. EVERY engine wet sump oil pump is a positive displacement pump. I believe all of the dry sump pumps are as well. It could be possible to use a centrifugal pump, but operating characteristics of a centrifugal pump don't match engine lubrication needs very well.
I do not understand why you would say that a Melling pump would be all done by 3000 rpm. Melling makes most of the oil pumps that are sold for the US market. There is nothing about the design of a Melling pump, or any engine oil pump of which I am aware, that would make that happen.
On the other hand, if the oil pickup tube is constricted, or if the oil gets all foamy above 3000 rpm, then something like what I think you are describing is possible, due to cavitation.
R.
