pics of my bearings for the 408 #1813850
04/28/15 01:32 PM
04/28/15 01:32 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
the bearings are set up L to R #1 main thru #5 and same on rods L to R. uppers are at top and lowers on bottom. they have about 40-50 passes and 1500-2000 miles i'm guessing. what do you think? did they get enough oil and especially #1 main and rod?
Re: pics of my bearings for the 408 [Re: mopar dave] #1813855
04/28/15 01:42 PM
04/28/15 01:42 PM
Mt Morris Michigan
Mt Morris Michigan
ok, how do you add pics? why did they make this so difficult?
Re: pics of my bearings for the 408 [Re: mopar dave] #1813868
04/28/15 02:04 PM
04/28/15 02:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: pics of my bearings for the 408 [Re: pittsburghracer] #1813886
04/28/15 02:29 PM
04/28/15 02:29 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks i'll try again
Re: pics of my bearings for the 408 [Re: mopar dave] #1813890
04/28/15 02:34 PM
04/28/15 02:34 PM
Mt Morris Michigan
Mt Morris Michigan
heres some more.
Re: pics of my bearings for the 408 [Re: mopar dave] #1813952
04/28/15 03:51 PM
04/28/15 03:51 PM
The rod bearing look good to me up I would check the actual run out on the # 2 and #4 crankshaft mains to see what is causing those two main bearings to look like they do scope I've seen more than one SB crankshaft have run out on the #2 main shruggy Let us know what you find out up
Re: pics of my bearings for the 408 [Re: Cab_Burge] #1813998
04/28/15 04:55 PM
04/28/15 04:55 PM
Mt Morris Michigan
Mt Morris Michigan
OK. I will have that checked. Let ya know.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814153
04/28/15 09:02 PM
04/28/15 09:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO it's not a oiling problem, I'm betting the crank is a mess. It never was right judging by those rod bearings, they are messed up too. It looks like there taper in the journals?
Re: pics of my bearings for the 408 [Re: Challenger 1] #1814356
04/29/15 01:06 AM
04/29/15 01:06 AM
Mt Morris Michigan
Mt Morris Michigan
the upper rod bearings look to be more worn in the center while the lowers appear to be more worn on the outside edges. i'll have to mic the crank when I get time.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814421
04/29/15 05:45 AM
04/29/15 05:45 AM
P
Porter67 Offline
Porter67  Offline
P
I noticed you used upper halves on the lower mains for 360 oiling? Possibly?
What crank?
And id guess its as delivered. If this is so its the main reason I will run the high side of the bearing clearance which is ok but I always end up going 10/10 with a good crank grinder.
Some will go 10/10 from the gate.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814440
04/29/15 08:53 AM
04/29/15 08:53 AM
Cincinnati, Ohio
Cincinnati, Ohio
The upper rod bearings should be the only ones showing wear, the lowers are just along for the ride. Hows the rod bearings crush? I bet not good?
Re: pics of my bearings for the 408 [Re: Challenger 1] #1814498
04/29/15 11:51 AM
04/29/15 11:51 AM
Mt Morris Michigan
Mt Morris Michigan
the backs of the shells look like they might be alittle worn. hard to tell. what am I looking for exactly? some are black and some I can see alittle copper.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814531
04/29/15 12:52 PM
04/29/15 12:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
You want to see how they "snap" into the rod. Should fit tight in the rod. (crush)
And you measure the width on the rod bearing to see if it spread any. Look real close and you can see if there "spread" with your eyes right in the middle.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814553
04/29/15 01:28 PM
04/29/15 01:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
[code][/code]
If my bearings looked like that after the amount of use you described above, I'd be concerned about the source of the problem. The rods look "so-so" at best, and a couple of those crank bearings just plain look bad, maybe like temporay oil starvation.
Not sure I can add any more to what others have said. I, too, suspect the crank has issues, but would want to verify there are no obstructions in the oiling passages, etc.
Re: pics of my bearings for the 408 [Re: BradH] #1814585
04/29/15 02:44 PM
04/29/15 02:44 PM
Mt Morris Michigan
Mt Morris Michigan
when I removed the bearings from the rods they felt tight and a couple where alittle tougher to get out. I will have the rods checked as well as the crank as it has micro grooves in the journals. I plan on some oiling mods and a new pump that I never knew existed. this new pump oils according to rpm and is not done by 3000rpm like the melling pumps. suppose to be easier on bronze gears as well.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814598
04/29/15 03:04 PM
04/29/15 03:04 PM
dogdays Offline
dogdays  Offline
I don't understand that last comment. ANY positive displacement pump oils by rpm. The flow out of the pump is directly proportional to the pump speed, which is directly proportional to crankshaft speed. EVERY engine wet sump oil pump is a positive displacement pump. I believe all of the dry sump pumps are as well. It could be possible to use a centrifugal pump, but operating characteristics of a centrifugal pump don't match engine lubrication needs very well.
I do not understand why you would say that a Melling pump would be all done by 3000 rpm. Melling makes most of the oil pumps that are sold for the US market. There is nothing about the design of a Melling pump, or any engine oil pump of which I am aware, that would make that happen.
On the other hand, if the oil pickup tube is constricted, or if the oil gets all foamy above 3000 rpm, then something like what I think you are describing is possible, due to cavitation.
R.
Re: pics of my bearings for the 408 [Re: dogdays] #1814625
04/29/15 03:43 PM
04/29/15 03:43 PM
Mt Morris Michigan
Mt Morris Michigan
I was given the info by Mopar Performance shop by me. I do not understand it fully myself. even though themelling pump spins faster above 3000rpm, it doesn't move any more oil thru the engine as i'm told. only thing I can figure is it creates too much internal pressure above 3000 and the pump bleed valve opens and it just dumps the excess oil? I don't know the name of this new pump, but it just keeps pumping and moving oil no matter the rpm and it does not work had at low rpm. I will know more about it next week.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814645
04/29/15 04:28 PM
04/29/15 04:28 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What pump?
Re: pics of my bearings for the 408 [Re: justinp61] #1814653
04/29/15 04:48 PM
04/29/15 04:48 PM
Mt Morris Michigan
Mt Morris Michigan
I don't know. He didn't offer to tell me and I didn't ask. I do know I will be buying one. There about $180.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814661
04/29/15 05:11 PM
04/29/15 05:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Who did you talk to?
