Re: bump steer early b bodies
[Re: Jimi_Vignogna]
#1810773
04/24/15 09:48 AM
04/24/15 09:48 AM
Posts: 2,923 A shed in England
Tig
A shed in England
E body but the principles the same I'd guess. We spent a whole weekend installing tubular UCA's and setting up the toe curves with a caster gauge, mirrors and stuff. We couldn't eliminate it completely (we have around 6 inches of upward travel). Can't remember what we ended up with toe amount wise but we did heat up the bottom steering link on the hub and bend it upwards some which helped a lot. It's probably back to crap now due to all the wheelies though Hth's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: old_racer]
#1810817
04/24/15 11:34 AM
04/24/15 11:34 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
My take on your question is : yes you can get it REALLY close or even perfect. However as I`m sure you understand ,measured and driven patterns are WAY different. Who knows exactly what the suspension angles really are at speed or unloaded at launch,braking etc.... On my E-body I spent ALOT of time to get zero change at all heights but when the tire leaves the ground it still toes in 3/16". Car drives really well,and the tires show perfect wear. So must be close enough. IMO get as close as you can then adjust based on results.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
