440-1 header flange #1810058
04/23/15 12:05 PM
04/23/15 12:05 PM
michigan
turbo toad Offline OP
michigan
Im in the process of starting the mock up of my boosted low deck big block swap in my valiant and im trying to source out a set a 1/2 thick header flanges for a set of 440-1 heads does anyone have a cad drawing of the header flanges or a basic drawing of set of flanges for these heads i could have turned into a cad drawing. Any and all help is always appreciated
Thanks Aaron
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: 440-1 header flange [Re: turbo toad] #1810137
04/23/15 01:43 PM
04/23/15 01:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Headman makes nice flanges with stubs
Re: 440-1 header flange [Re: turbo toad] #1810144
04/23/15 01:50 PM
04/23/15 01:50 PM
michigan
michigan
Thanks but stubs arent going to work for me i need all the room i can get also i have a shop thats willing to cut some 1/2 thick flanges for $90 i just need a pattern or template
Aaron
Re: 440-1 header flange [Re: turbo toad] #1810200
04/23/15 03:13 PM
04/23/15 03:13 PM
How about using a header gasket as your template? shruggy
Re: 440-1 header flange [Re: Cab_Burge] #1810239
04/23/15 04:18 PM
04/23/15 04:18 PM
michigan
michigan
Yes thats a option ive thought about but i was hoping another memeber may already have the dimension and would be willing to share.
Aaron
Re: 440-1 header flange [Re: turbo toad] #1810256
04/23/15 04:49 PM
04/23/15 04:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440-1 header flange [Re: pittsburghracer] #1810260
04/23/15 04:52 PM
04/23/15 04:52 PM
PA.
"Little"John
"Little"John
PA.
Hope to get my headers made very soon for the new car
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 440-1 header flange [Re: pittsburghracer] #1810271
04/23/15 05:05 PM
04/23/15 05:05 PM
michigan
michigan
Pittsburghracer whats the thickness of those flanges and if you dont mind me asking what was the damage to your pocket book.
Re: 440-1 header flange [Re: turbo toad] #1810284
04/23/15 05:20 PM
04/23/15 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I looked around for 1/2" flanges and most wont make them.. and the
ones that would wanted about $200.. you would be better off measuring
a gasket and having them cut at that shop.. also.. make them out
of stainless... I ended up making most of my flanges
wave
Re: 440-1 header flange [Re: turbo toad] #1810285
04/23/15 05:22 PM
04/23/15 05:22 PM
PA.
"Little"John
"Little"John
PA.
They are 3/8 thick and I will check when I get in the house but think they were around 200 dollars shipped
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 440-1 header flange [Re: turbo toad] #1810324
04/23/15 06:26 PM
04/23/15 06:26 PM
michigan
michigan
Ok cool thanks for the advice guys i might just have to order a gasket and take it in to the shop and have them use it for a template
Aaron
Re: 440-1 header flange [Re: turbo toad] #1810346
04/23/15 07:01 PM
04/23/15 07:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the gasket lines up well with your heads... it shouldnt
take the shop long to set up a CNC program to cut the flanges based
on the gasket... but it will add a few bucks to the cost
wave
Re: 440-1 header flange [Re: turbo toad] #1810385
04/23/15 08:00 PM
04/23/15 08:00 PM
michigan
michigan
I just ordered a set of gaskets from tti
Re: 440-1 header flange [Re: turbo toad] #1810465
04/23/15 09:29 PM
04/23/15 09:29 PM
AndyF Offline
AndyF  Offline
Schoenfeld has flanges. I think they even provide dimensions on their website.
Re: 440-1 header flange [Re: AndyF] #1810544
04/23/15 10:47 PM
04/23/15 10:47 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Check the website for Flatout Gaskets. They used to have drawings with dimensions of all of the gaskets they made.
[image][/image]
Re: 440-1 header flange [Re: Cab_Burge] #1810624
04/24/15 12:19 AM
04/24/15 12:19 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
Cab, wave I tried to send you a pm and your mail box is full?
Sorry for the hijack..
Thx. Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: 440-1 header flange [Re: AndyF] #1810764
04/24/15 09:17 AM
04/24/15 09:17 AM
michigan
michigan
Thanks AndyF i think found what i needed the funny thing is i have there website bookmarked on my phone and was looking on there site earlier in the day but i forgot they have the dimension but thank you
Aaron
Re: 440-1 header flange [Re: turbo toad] #1810894
04/24/15 01:15 PM
04/24/15 01:15 PM
michigan
michigan
I found these and thought i should post them
Re: 440-1 header flange [Re: turbo toad] #1810904
04/24/15 01:26 PM
04/24/15 01:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll give you a couple of suggestions that help.. when you
get done building the headers cut the flanges so the end tubes
are free to move... and on each tube drill 1 hole larger so
each section of the flange can grow and move
wave
Re: 440-1 header flange [Re: turbo toad] #1810933
04/24/15 01:59 PM
04/24/15 01:59 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Call TTI or Hedman and see if they will sell you flanges.
