440-1 header flange
#1810058
04/23/15 12:05 PM
04/23/15 12:05 PM
Posts: 368 michigan
turbo toad
michigan
Im in the process of starting the mock up of my boosted low deck big block swap in my valiant and im trying to source out a set a 1/2 thick header flanges for a set of 440-1 heads does anyone have a cad drawing of the header flanges or a basic drawing of set of flanges for these heads i could have turned into a cad drawing. Any and all help is always appreciated Thanks Aaron
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: 440-1 header flange
[Re: turbo toad]
#1810144
04/23/15 01:50 PM
04/23/15 01:50 PM
Posts: 368 michigan
turbo toad
michigan
Thanks but stubs arent going to work for me i need all the room i can get also i have a shop thats willing to cut some 1/2 thick flanges for $90 i just need a pattern or template Aaron
[Re: Cab_Burge]
#1810239
04/23/15 04:18 PM
04/23/15 04:18 PM
Posts: 368 michigan
turbo toad
michigan
How about using a header gasket as your template? Yes thats a option ive thought about but i was hoping another memeber may already have the dimension and would be willing to share. Aaron
[Re: pittsburghracer]
#1810260
04/23/15 04:52 PM
04/23/15 04:52 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hope to get my headers made very soon for the new car
#1810271
04/23/15 05:05 PM
04/23/15 05:05 PM
Posts: 368 michigan
turbo toad
michigan
Hope to get my headers made very soon for the new car Pittsburghracer whats the thickness of those flanges and if you dont mind me asking what was the damage to your pocket book.
[Re: turbo toad]
#1810284
04/23/15 05:20 PM
04/23/15 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I looked around for 1/2" flanges and most wont make them.. and the ones that would wanted about $200.. you would be better off measuring a gasket and having them cut at that shop.. also.. make them out of stainless... I ended up making most of my flanges
[Re: turbo toad]
#1810285
04/23/15 05:22 PM
04/23/15 05:22 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They are 3/8 thick and I will check when I get in the house but think they were around 200 dollars shipped
[Re: turbo toad]
#1810324
04/23/15 06:26 PM
04/23/15 06:26 PM
Posts: 368 michigan
turbo toad
michigan
Ok cool thanks for the advice guys i might just have to order a gasket and take it in to the shop and have them use it for a template Aaron
[Re: turbo toad]
#1810346
04/23/15 07:01 PM
04/23/15 07:01 PM
MR_P_BODY
Make sure the gasket lines up well with your heads... it shouldnt take the shop long to set up a CNC program to cut the flanges based on the gasket... but it will add a few bucks to the cost
[Re: turbo toad]
#1810385
04/23/15 08:00 PM
04/23/15 08:00 PM
Posts: 368 michigan
turbo toad
michigan
I just ordered a set of gaskets from tti
[Re: Cab_Burge]
#1810624
04/24/15 12:19 AM
04/24/15 12:19 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Cab, I tried to send you a pm and your mail box is full? Sorry for the hijack.. Thx. Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: AndyF]
#1810764
04/24/15 09:17 AM
04/24/15 09:17 AM
Posts: 368 michigan
turbo toad
michigan
Schoenfeld has flanges. I think they even provide dimensions on their website. Thanks AndyF i think found what i needed the funny thing is i have there website bookmarked on my phone and was looking on there site earlier in the day but i forgot they have the dimension but thank you Aaron
[Re: turbo toad]
#1810904
04/24/15 01:26 PM
04/24/15 01:26 PM
MR_P_BODY
I'll give you a couple of suggestions that help.. when you get done building the headers cut the flanges so the end tubes are free to move... and on each tube drill 1 hole larger so each section of the flange can grow and move
