Index racers ---- weight boxes? #1805746
04/17/15 05:40 PM
04/17/15 05:40 PM
Aurora, Oh.
max_maniac Offline OP
Aurora, Oh.
Show me your weight boxes and what you use to fill them with and also where do you place them for best results. If not weight boxes what else do you use. Looking for idea's to add anywhere from 10 lbs to 200 lbs.
Thanks up
Re: Index racers ---- weight boxes? [Re: max_maniac] #1805922
04/17/15 10:43 PM
04/17/15 10:43 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Try this....
If you like drag racing, support your local track.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1806026
04/18/15 01:57 AM
04/18/15 01:57 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Excuse the mess, street car on Drag Week! I ran it in index classes also, and went with the competition engineering weight box/ battery box, mounted on the opposite side of the trunk from the batteries. Had lead shot in bags 25lbs. and some 10lb. steel weights, etc, will easily hold 200lbs.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Index racers ---- weight boxes? [Re: max_maniac] #1806114
04/18/15 10:00 AM
04/18/15 10:00 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I use these weights. They are approximately 10 lbs each and are bolted to the rear most trunk floor through the frame rails.
Stuck down the middle of the weights is a T Handle I made to change up to 160 lbs of weight in a couple of minutes.
I bought the complete weight bench setup from Habitat for Humanity for next to nothing for the weights.
NMCA NSS 67 Coronet
Re: Index racers ---- weight boxes? [Re: Barry70GTX] #1806322
04/18/15 03:28 PM
04/18/15 03:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use cases of beer. That's why my car is always faster on Sunday than Saturday.
Doug
Re: Index racers ---- weight boxes? [Re: max_maniac] #1806349
04/18/15 04:32 PM
04/18/15 04:32 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Used to use weights but two years ago went to the ET Genie http://www.etgenie.com/. Using Crewcheif Pro I am able to adjust the genie to run within a .01 virtually every time. Might be something to look at and is legal in most index classes as it is a manual adjustment done from outside of the car.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1807072
04/19/15 06:06 PM
04/19/15 06:06 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Russ,
This is the box I use it's homemade. I can put 8 25 pound bags of lead shot in it.I wouldn't recommend putting more than 150 pounds in the trunk, you may need to reset the suspension plus that extra weight can really slow down how quick your car reacts.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1807294
04/19/15 10:38 PM
04/19/15 10:38 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
My weight box is a battery box. As you can see, the box weighs 25#. My added weight are bags of tungsten rounds:
1979 AMC Spirit, NHRA Q/SA
Re: Index racers ---- weight boxes? [Re: longram60] #1808489
04/21/15 11:08 AM
04/21/15 11:08 AM
Aurora, Oh.
Aurora, Oh.
Thanks for the idea's guys up . I have always tried to adjust the throttle cable or just played the stripe at top end with the brakes and think now I will try to use weight. Looks like a box with some bags of lead shot and maybe use the trunk and maybe a box where the back seat would be to help spread some of the weight around.
Russ
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808505
04/21/15 11:26 AM
04/21/15 11:26 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I use an EZ plate restrictor plate system under each carb. i needed to slow down close to 6 tenths. I went to a weight box as well this year to help. In good air I was restricting the car so much that i had no throttle response at the tree. Obviously bad. So this year i have been working on finding middle ground on the plates and using weight to finish me off to the index.
Re: Index racers ---- weight boxes? [Re: 66coronet] #1808521
04/21/15 11:51 AM
04/21/15 11:51 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I "believe" some index racers use the MSD Power Grid and program taking out timing at the start of a run to slow them down. If you look at some of the 60ft times you can see how they slow it down at the start of the run.
Re: Index racers ---- weight boxes? [Re: nss guy] #1808578
04/21/15 01:14 PM
04/21/15 01:14 PM
Minn
SportF Offline
SportF  Offline
Minn
Is this legal in NSS, NMCA rules? It's not in Victory NSS series. This is the one thing that can completely foul up NSS or any other non-electronic racing. Heck, as far as I am concerned, it will foul up ALL racing. Not only can you slow up 60 ft times, there is a world of "adjustments" that can be made down track. Read articles about "slew rate" in drag racing.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808593
04/21/15 01:38 PM
04/21/15 01:38 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
It is not legal the way I read the rules.
NHRA allowed list has the Grid components listed as prohibited. The NMCA rules say if it is on the NHRA allowed ignition list then you can use it. They checked my ignition at Atlanta NMCA.
Re: Index racers ---- weight boxes? [Re: 66coronet] #1808615
04/21/15 02:16 PM
04/21/15 02:16 PM
Minn
SportF Offline
SportF  Offline
Minn
66 coronet, that is good to hear. If this is allowed we might as well drag race on a practice tree, races would be decided on the starting line every time.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808616
04/21/15 02:16 PM
04/21/15 02:16 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Power Grid 7730 is NHRA acceptable, the 7761 and 7762 are NOT acceptable.
The 7730 allows to pull timing out or slew it, but not rpm
And no I don't run one, I'm still running the old MSD 6T nascar box.
Re: Index racers ---- weight boxes? [Re: nss guy] #1808623
04/21/15 02:26 PM
04/21/15 02:26 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
I SAY IF YOU CAN HOOK A LAPTOP TO IT OR CAN CHASE THE DOTS WITH IT IT SHOULD BE ILLEGAL!.
Re: Index racers ---- weight boxes? [Re: 64hemi330sedan] #1808638
04/21/15 02:53 PM
04/21/15 02:53 PM
Minn
SportF Offline
SportF  Offline
Minn
I am with you there!
Re: Index racers ---- weight boxes? [Re: SportF] #1808715
04/21/15 04:33 PM
04/21/15 04:33 PM
Aurora, Oh.
Aurora, Oh.
Same here I do not agree with allowing the new programmable digital boxes and I also have seen some weird 60ft and 1/8 mile times as compared to the 1/4 mile final ET. However like Jim said the boxes are legal. I did ask once when they started to allow the digital boxes and was told that if anyone is caught at the RACE with the laptop hooked up they would be DQ'd. However who is really going to police that???? no I can see and have "heard of" some doing it and if I ever really see them I will speak up. I still run a 6AL digital but not programmable box. Myself I think the digital box has no place in an NSS car. If it gets out of hand I'll just drop out and race points locally shruggy
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808723
04/21/15 04:45 PM
04/21/15 04:45 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Not to worry I will put a retro "Mattie box" in there for you and then you just have to pay attention to the light you cut - everything else will take car of itself!!!
If that don't work I will have you plug your "smart phone" like your charging it and the rest will take car of itself.......
More than one way to fool the on-lookers
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808737
04/21/15 05:09 PM
04/21/15 05:09 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Russ
If all your trying to do is slow it down why don't you just lower your shift points?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
