How do you tell what wiper motor came originally on your GTS #1808019
04/20/15 08:01 PM
04/20/15 08:01 PM
blewbyu Offline OP
blewbyu  Offline OP
I have a 69 GTS Date M Code and thought it had the original wiper motor on the car until I removed it this weekend. It looks like it has been changed at some time but the wiring harness looks like the original. It has the large canister style rather then the flat faced type. I think this is the 2 speed and the other is a variable which I though all GTS should have. Is there a spot on my build sheet that would tell which one the car should have had either a standard 2 speed type or Variable speed. I can not find a part number on the canister style 2 speed that I removed, do these have a part number and date codes on them and where would it be located. I have seen the variable speed with part numbers and date codes.
Any help would be appreciated.
Re: How do you tell what wiper motor came originally on your GTS [Re: blewbyu] #1808168
04/20/15 10:56 PM
04/20/15 10:56 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Does it have a foot pump wahser in the floor? If so it's a 2 speed car if my info is correct, 3 speed had an electric pump in the tank. I have a GTS with a 2 speed and a foot pump, 3 speed was an option. I'll study a build sheet and see where the box is and report back.
8th line on the sheet, J25 is the code and shoud be on the tag as well or at least it was on a 69 Formula S I looked at yesterday.
Careful, your character's showing!
Re: How do you tell what wiper motor came originally on your GTS [Re: mopar346] #1808199
04/20/15 11:26 PM
04/20/15 11:26 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
The 2 sp motor in 69 had no part number or date code stamped in them.
NS1AAR
Re: How do you tell what wiper motor came originally on your GTS [Re: mopar346] #1808438
04/21/15 10:14 AM
04/21/15 10:14 AM
blewbyu Offline OP
blewbyu  Offline OP
Yes I have a foot pump and I got my build sheet from my safety deposit box and I now see J25 and it is not marked so looks like it is correct as not on fender tag either.
Re: How do you tell what wiper motor came originally on your GTS [Re: ns1aar] #1808439
04/21/15 10:15 AM
04/21/15 10:15 AM
blewbyu Offline OP
blewbyu  Offline OP
Re: How do you tell what wiper motor came originally on your GTS [Re: blewbyu] #1808550
04/21/15 12:38 PM
04/21/15 12:38 PM
mopar346 Offline
mopar346  Offline
No frills baby, just motor! up
Re: How do you tell what wiper motor came originally on your GTS [Re: blewbyu] #1808650
04/21/15 03:05 PM
04/21/15 03:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Same for 68 GTS. I have a foot pump with a 2 speed wiper. It's on my build sheet
Abe Lincoln
Re: How do you tell what wiper motor came originally on your GTS [Re: blewbyu] #1809663
04/22/15 08:00 PM
04/22/15 08:00 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
The J25 3 speed wiper would be on the fender tag. I have the 2 speed w/ foot pump in my GTS as well. Point that out to some of the younger crowd next time you have your car out. Not only do they NOT know what a floor dimmer switch is, but a foot pump washer will really confuse them!
Re: How do you tell what wiper motor came originally on your GTS [Re: fjr340gts] #1809687
04/22/15 08:42 PM
04/22/15 08:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
67 GTS's all had the three speed, 68 and 69 could have either. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: How do you tell what wiper motor came originally on your GTS [Re: fjr340gts] #1809691
04/22/15 08:51 PM
04/22/15 08:51 PM
blewbyu Offline OP
blewbyu  Offline OP
No J25 on fender tag
Re: How do you tell what wiper motor came originally on your GTS [Re: blewbyu] #1810473
04/23/15 09:37 PM
04/23/15 09:37 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would definitely say 2-speed, most I have seen have them.
A-Body's RULE!
