Rear rotors removal on a 2500 #1806292
04/18/15 02:36 PM
04/18/15 02:36 PM
USA
Lawn Monkey Offline OP
USA
Doing rear brakes tomorrow on a 2500 , with the calipers and mounts removed do the rotors just slide off? Or do I need special tools?
Re: Rear rotors removal on a 2500 [Re: Lawn Monkey] #1806375
04/18/15 05:38 PM
04/18/15 05:38 PM
Guitar Jones Offline
They'll come off but they may need some persuasion from a BFH.
Re: Rear rotors removal on a 2500 [Re: Guitar Jones] #1806421
04/18/15 07:02 PM
04/18/15 07:02 PM
USA
USA
Cool thats what I was hoping to hear , got the BFH ready
Re: Rear rotors removal on a 2500 [Re: Lawn Monkey] #1806574
04/18/15 11:40 PM
04/18/15 11:40 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Yes, mine were very rusty but they came off which some patience. spraying and hammering.
Re: Rear rotors removal on a 2500 [Re: mopars4ever] #1807064
04/19/15 05:53 PM
04/19/15 05:53 PM
Lehigh Acres, Florida
rickstershemi Offline
A little heat helps as well.....
Rickster
Re: Rear rotors removal on a 2500 [Re: rickstershemi] #1807340
04/19/15 11:35 PM
04/19/15 11:35 PM
USA
USA
Stuck tight, tried BFH,pry bar and a slap hammer no budge , going to purchase a puller
Re: Rear rotors removal on a 2500 [Re: Lawn Monkey] #1807382
04/20/15 12:36 AM
04/20/15 12:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What kind of emergency brake setup do those use?
Re: Rear rotors removal on a 2500 [Re: Lawn Monkey] #1807539
04/20/15 09:38 AM
04/20/15 09:38 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Let's hope he released the emergency brake.
Re: Rear rotors removal on a 2500 [Re: Lawn Monkey] #1808706
04/21/15 04:21 PM
04/21/15 04:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
hope the Ebrake if inside dosnet fall apart.I had a bunch at the shop that the linings fell off the E shoes.I spray penetrating fluid around the hub and then smack the rotors and they usually pop. Then antisieze when I reinstall the new rotors.Rocky
Chrysler Firepower
Re: Rear rotors removal on a 2500 [Re: therocks] #1809518
04/22/15 04:03 PM
04/22/15 04:03 PM
USA
USA
E brake working fine , not tight don't think its hung up on the e brake, searching for a puller.
