Edelbrock big block water pump #1806655
04/19/15 01:42 AM
04/19/15 01:42 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
MOPAR brethren, I picked up an Edelbrock water pump for a future project a while back because they were offering $25 off and a T-shirt. My old pump was working OK, although when making multiple back to back passes my engine would get significantly hotter every round, and sometimes on the street it would get hot if I got stuck in traffic. I had the front cover off the motor recently, so I decided to install this pump and see if it made a difference. Now my 4100lb, low ll second car runs cool round after round. Recommend you check one out if you're having cooling issues. Now get out there and burn some rubber.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Edelbrock big block water pump [Re: Lifsgrt] #1806807
04/19/15 11:51 AM
04/19/15 11:51 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
we have run an eddy water pump on our shop jeep with a tuned port sbc for over 10 yrs, they do work great, especially when idling or at slow speeds.
Re: Edelbrock big block water pump [Re: Lifsgrt] #1806978
04/19/15 03:46 PM
04/19/15 03:46 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Its a superior piece. Spendy but you do get results for your coin.
I want my fair share
