MOPAR brethren, I picked up an Edelbrock water pump for a future project a while back because they were offering $25 off and a T-shirt. My old pump was working OK, although when making multiple back to back passes my engine would get significantly hotter every round, and sometimes on the street it would get hot if I got stuck in traffic. I had the front cover off the motor recently, so I decided to install this pump and see if it made a difference. Now my 4100lb, low ll second car runs cool round after round. Recommend you check one out if you're having cooling issues. Now get out there and burn some rubber.
