528 hemi cam install question ?
#1804917
04/16/15 01:36 PM
04/16/15 01:36 PM
Posts: 73 Toronto,Canada
wkeggenhoff
Toronto,Canada
MP/ Ray Barton 528 Hemi. Going to install new cam this summer. Assuming engine was built correctly and cam degreed, Balencer marking, pointer and cam and sprockets are marked correctly should I be worried about degreeing cam again if it is going to be installed straight up ?
If yes I guess i will have to make a tool for piston stop for degreeing cam and an air adapter to pressurize cylinder when I remove and install new valve springs.
Can anyone recommend a good valve spring compressor for doing them in car ?
Thanks Werner
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: 528 hemi cam install question ?
[Re: wkeggenhoff]
#1804938
04/16/15 02:10 PM
04/16/15 02:10 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
I have seen two cams and or timing sets in the last two weeks that had the cams retarded 13 degrees in both motors There is no way I would change one part of the valve train drive or cam on a existing motor and not verify the cam lobe centers on the new cam or timing set, even if just changing the chain As far as changing the valve springs on the heads on the motor it depends if you have a stock rocker arm set up or the after market set up like bolt on Jesels or some other brand If stock I think LSM has a tool to use BTW, do you have a way of checking the valve spring pressures now and do you have a spec. on them when installed new? If not you may be shooting yourself in the foot by changing them
[Re: wkeggenhoff]
#1805007
04/16/15 03:28 PM
04/16/15 03:28 PM
Posts: 12,108 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Two thoughts on this. First, I never assume anything on a hi performance engine. And second, I never install a cam or chain without degreeing them in, especially on a hi performance engine. Been burned too many times before I learned those lessons.
And using air pressure to hold valves is a bit risky for a couple of reasons. Have you thought about using plastic rope inserted into the cylinder through the plug hole, then rotate the piston up till it compresses the rope in the chamber and holding the valves. That's the way we do it. Simple and fairly foolproof. Unlike air.
Master, again and still
[Re: mickm]
#1805791
04/17/15 07:09 PM
04/17/15 07:09 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
That's a fine looking tool! I made a pair 15 years ago and used them twice. insert RollEyes
