Page 1 of 5 1 2 3 4 5
This Is A New One On Me.. Trans Help.. UPDATE.. Same Thing #1803372
04/14/15 05:19 PM
04/14/15 05:19 PM
MR_P_BODY Offline OP
I took the Rampage out for a put to see if it pulled left or
right.. thats fine.. BUT as it shifted through the gears(the
shifter is in drive) as soon as it goes into high gear the
rear tires LOCK UP.. as soon as it down shifts out of high
it frees up.... this is something I have never seen before..
any ideas... that GOD I was taking it easy and was on my street
and no traffic .. because it went side ways on the lock up
thanks
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1803378
04/14/15 05:25 PM
04/14/15 05:25 PM
The only thing I can think of is the band and the clutches
are on together... correct me if I'm wrong here
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1803384
04/14/15 05:30 PM
04/14/15 05:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is what I call 2-3 tie-up, caused by to fast of a band apply or to quick of a front clutch apply. A 5.1 band lever can cause this and so can removing front drum springs. BUT it should free up if you keep driving, if it is truly locking up, the band is not releasing enough at all.
Mopar to the bone!!!
Re: This Is A New One On Me.. Trans Help [Re: 72Swinger] #1803389
04/14/15 05:35 PM
04/14/15 05:35 PM
I'll check the band adjustment but I'm sure its backed off
2 1/8 turns... and its locking up.. tires screaming and the
back end sliding out side ways
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1803404
04/14/15 05:47 PM
04/14/15 05:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it totally locked up (not just temporary nose over) the front servo isn't releasing....could be broken piston/ring.
Re: This Is A New One On Me.. Trans Help [Re: John_Kunkel] #1803413
04/14/15 05:53 PM
04/14/15 05:53 PM
Whats the test for this John
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1803505
04/14/15 07:29 PM
04/14/15 07:29 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Put a gauge in the front test port & run it on jack stands.
Re: This Is A New One On Me.. Trans Help [Re: rickraw] #1803508
04/14/15 07:32 PM
04/14/15 07:32 PM
And what pressure should I see when it locks up
EDIT
I just checked my 518 book and it calls for 2 turns
out on both bands.. I'll check it but I'm sure its there
so it must be jammed up in the piston
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1803522
04/14/15 07:44 PM
04/14/15 07:44 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Apply pressure should be around 155#.
Re: This Is A New One On Me.. Trans Help [Re: rickraw] #1803568
04/14/15 09:00 PM
04/14/15 09:00 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
I had the same problem with a 904 I built .they put it in ,took it out and drove it it was locking up in 3rd .I went to the shop and put a pressure guage on the front servowhen it shifted into 3rd it never released the band I checked the linkage adjustment it was off. I put the unit in 3rd and adjusted the cable so it would go right in the problem was fixed.but you know how it is the trans builder is always at fault lol.hope this helps.
Re: This Is A New One On Me.. Trans Help [Re: B1Johnny] #1803598
04/14/15 09:38 PM
04/14/15 09:38 PM
iagreeCheck the shifter cable adjustments, especially in high gear.
Re: This Is A New One On Me.. Trans Help [Re: Cab_Burge] #1803612
04/14/15 09:52 PM
04/14/15 09:52 PM
I'll check a few things tomorrow.. shifter, band adjustment
and if they look good I'll pull the valve body and do a air
test on the servo
wave
Re: This Is A New One On Me.. Trans Help [Re: 72Swinger] #1803622
04/14/15 09:59 PM
04/14/15 09:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Matt and I ran into this one to while testing his 727 transmission in the shop on jack stands. The wheels would completely stop in 3rd gear. We removed the aftermarket lever on our CRT transmission and the car ran better than it ever did. Lesson learned and the lever is in my junk pile on the shelf.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: This Is A New One On Me.. Trans Help [Re: pittsburghracer] #1803648
04/14/15 10:17 PM
04/14/15 10:17 PM
I have the factory lever on it.. I'll check things
out tomorrow
EDIT
I sure hope its something as simple as the cable adjustment
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1804135
04/15/15 01:27 PM
04/15/15 01:27 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
had this happen on mine when I installed the first T-A valve body. Luckily, my car was still on jack stands when I found it. Talked with Paul Forte about it over the phone, and he was convinced I had done something wrong (as was I), but agreed to take a look at the valve body, so I sent it to him. He called me a week later, said he had installed it into his test vehicle and it did the same thing. Locked up in D. He appologized profusely and sent me a new valve body which worked fine. My point is simply that it could be in the valve body (???).
Re: This Is A New One On Me.. Trans Help [Re: StealthWedge67] #1804163
04/15/15 01:57 PM
04/15/15 01:57 PM
I checked the cable adjustment on the shifter.. that was perfect
and I checked the band adjustment which was good.. it still locked
up but its on the hoist now...now I'm getting ready to drop the pan
and the valve body... I'm gonna do a air check on the servo to see
if its moving freely and for a crack in it
EDIT
Anyone have any other ideas before I drop the pan.... by the way
I checked the cable in low and in drive positions and both were
perfect
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1804182
04/15/15 02:27 PM
04/15/15 02:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think there is a port at the band servo for external access if you have a pressure gauge? Maybe im dreaming, but that it about it without dropping the pan.
Re: This Is A New One On Me.. Trans Help [Re: 72Swinger] #1804192
04/15/15 02:36 PM
04/15/15 02:36 PM
UPDATE
I tested it with the OD OFF and it doesnt lock up.. flip the
OD ON and it locks up... so it has something to do with the
OD... now the next question is... what would happen IF I might
have the wires wrong and am trying to engage the lock up in
the conv ... but I dont have a lock up conv... would it direct
fluid to something that can lock it up shruggy
wave
Re: This Is A New One On Me.. Trans Help [Re: MR_P_BODY] #1804217
04/15/15 03:25 PM
04/15/15 03:25 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
IM out, forgot all about you having a 518. Im no help there.
Re: This Is A New One On Me.. Trans Help [Re: 72Swinger] #1804224
04/15/15 03:34 PM
04/15/15 03:34 PM
I might be running in uncharted waters here... being that
I am running a 518 that uses JUST OD... thats why I am
wondering if I hooked up the OD and LU solenoids backwards
and instead of energizing the OD solenoid I am energizing the
LU solenoid and without a LU conv what would happen... I still
want to do another test to verify this.. I should see the wheel
speed and the tach change if I flip the switch in 2nd gear( this
trans is in OD any time its engaged in the forward gears)
wave
