This Is A New One On Me.. Trans Help.. UPDATE.. Same Thing
#1803372
04/14/15 05:19 PM
04/14/15 05:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I took the Rampage out for a put to see if it pulled left or right.. thats fine.. BUT as it shifted through the gears(the shifter is in drive) as soon as it goes into high gear the rear tires LOCK UP.. as soon as it down shifts out of high it frees up.... this is something I have never seen before.. any ideas... that GOD I was taking it easy and was on my street and no traffic .. because it went side ways on the lock up thanks
Re: This Is A New One On Me.. Trans Help
[Re: MR_P_BODY]
#1803384
04/14/15 05:30 PM
04/14/15 05:30 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That is what I call 2-3 tie-up, caused by to fast of a band apply or to quick of a front clutch apply. A 5.1 band lever can cause this and so can removing front drum springs. BUT it should free up if you keep driving, if it is truly locking up, the band is not releasing enough at all.
Mopar to the bone!!!
[Re: 72Swinger]
#1803389
04/14/15 05:35 PM
04/14/15 05:35 PM
MR_P_BODY
I'll check the band adjustment but I'm sure its backed off 2 1/8 turns... and its locking up.. tires screaming and the back end sliding out side ways
[Re: MR_P_BODY]
#1803404
04/14/15 05:47 PM
04/14/15 05:47 PM
Posts: 25,945 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it totally locked up (not just temporary nose over) the front servo isn't releasing....could be broken piston/ring.
[Re: rickraw]
#1803508
04/14/15 07:32 PM
04/14/15 07:32 PM
MR_P_BODY
Put a gauge in the front test port & run it on jack stands. And what pressure should I see when it locks up EDIT I just checked my 518 book and it calls for 2 turns out on both bands.. I'll check it but I'm sure its there so it must be jammed up in the piston
[Re: B1Johnny]
#1803598
04/14/15 09:38 PM
04/14/15 09:38 PM
Posts: 43,282 Bend,OR USA
Cab_Burge
I had the same problem with a 904 I built .they put it in ,took it out and drove it it was locking up in 3rd .I went to the shop and put a pressure guage on the front servowhen it shifted into 3rd it never released the band I checked the linkage adjustment it was off. I put the unit in 3rd and adjusted the cable so it would go right in the problem was fixed.but you know how it is the trans builder is always at fault lol.hope this helps. Check the shifter cable adjustments, especially in high gear.
[Re: Cab_Burge]
#1803612
04/14/15 09:52 PM
04/14/15 09:52 PM
MR_P_BODY
I'll check a few things tomorrow.. shifter, band adjustment and if they look good I'll pull the valve body and do a air test on the servo
[Re: 72Swinger]
#1803622
04/14/15 09:59 PM
04/14/15 09:59 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That is what I call 2-3 tie-up, caused by to fast of a band apply or to quick of a front clutch apply. A 5.1 band lever can cause this and so can removing front drum springs. BUT it should free up if you keep driving, if it is truly locking up, the band is not releasing enough at all. Matt and I ran into this one to while testing his 727 transmission in the shop on jack stands. The wheels would completely stop in 3rd gear. We removed the aftermarket lever on our CRT transmission and the car ran better than it ever did. Lesson learned and the lever is in my junk pile on the shelf.
[Re: pittsburghracer]
#1803648
04/14/15 10:17 PM
04/14/15 10:17 PM
MR_P_BODY
I have the factory lever on it.. I'll check things out tomorrow EDIT I sure hope its something as simple as the cable adjustment
[Re: MR_P_BODY]
#1804135
04/15/15 01:27 PM
04/15/15 01:27 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
had this happen on mine when I installed the first T-A valve body. Luckily, my car was still on jack stands when I found it. Talked with Paul Forte about it over the phone, and he was convinced I had done something wrong (as was I), but agreed to take a look at the valve body, so I sent it to him. He called me a week later, said he had installed it into his test vehicle and it did the same thing. Locked up in D. He appologized profusely and sent me a new valve body which worked fine. My point is simply that it could be in the valve body (???).
[Re: StealthWedge67]
#1804163
04/15/15 01:57 PM
04/15/15 01:57 PM
MR_P_BODY
had this happen on mine when I installed the first T-A valve body. Luckily, my car was still on jack stands when I found it. Talked with Paul Forte about it over the phone, and he was convinced I had done something wrong (as was I), but agreed to take a look at the valve body, so I sent it to him. He called me a week later, said he had installed it into his test vehicle and it did the same thing. Locked up in D. He appologized profusely and sent me a new valve body which worked fine. My point is simply that it could be in the valve body (???). I checked the cable adjustment on the shifter.. that was perfect and I checked the band adjustment which was good.. it still locked up but its on the hoist now...now I'm getting ready to drop the pan and the valve body... I'm gonna do a air check on the servo to see if its moving freely and for a crack in it EDIT Anyone have any other ideas before I drop the pan.... by the way I checked the cable in low and in drive positions and both were perfect
[Re: MR_P_BODY]
#1804182
04/15/15 02:27 PM
04/15/15 02:27 PM
72Swinger
Nebraska
I think there is a port at the band servo for external access if you have a pressure gauge? Maybe im dreaming, but that it about it without dropping the pan.
[Re: 72Swinger]
#1804192
04/15/15 02:36 PM
04/15/15 02:36 PM
MR_P_BODY
UPDATE I tested it with the OD OFF and it doesnt lock up.. flip the OD ON and it locks up... so it has something to do with the OD... now the next question is... what would happen IF I might have the wires wrong and am trying to engage the lock up in the conv ... but I dont have a lock up conv... would it direct fluid to something that can lock it up
[Re: MR_P_BODY]
#1804217
04/15/15 03:25 PM
04/15/15 03:25 PM
72Swinger
Nebraska
IM out, forgot all about you having a 518. Im no help there.
[Re: 72Swinger]
#1804224
04/15/15 03:34 PM
04/15/15 03:34 PM
MR_P_BODY
I might be running in uncharted waters here... being that I am running a 518 that uses JUST OD... thats why I am wondering if I hooked up the OD and LU solenoids backwards and instead of energizing the OD solenoid I am energizing the LU solenoid and without a LU conv what would happen... I still want to do another test to verify this.. I should see the wheel speed and the tach change if I flip the switch in 2nd gear( this trans is in OD any time its engaged in the forward gears)
