Re: early A-body rear end options -Jeep?
[Re: syleng1]
#1801859
04/12/15 07:21 PM
04/12/15 07:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did this tweaking cover the change in bolt patterns? The Cuda has 5 on 4", the Jeep 5 on 4.5".
[Re: savoy64]
#1804077
04/15/15 12:23 PM
04/15/15 12:23 PM
Supercuda
About to go away
About to go away
up yours
look at valiant-duster-dart rearends---a while back i found a posi 8.25 at the pickapart under i think a 72 dart.... Wasn't stock, aside from the "posi", the 72's all had the 4" bolt pattern and there were no 4" bolt pattern 8 1/4's So someone probably swapped it in. 73 and up A bodies have the 8 1/4, but around here there are none in the yards anymore.
[Re: syleng1]
#1804084
04/15/15 12:29 PM
04/15/15 12:29 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
If you need an 8.25" Joe I have one under the '75 parts Dart.
"I think its got a hemi"
[Re: syleng1]
#1804087
04/15/15 12:31 PM
04/15/15 12:31 PM
Posts: 15,487 Florida
scratchnfotraction
94 jeep cherokee share the A-body 43" spring perch center BUT are on the wrong side of tube for axle over spring.
BUT I used them to line up the set I weld on.
I have an A-body 8 3/4 in my 88 D100 truck to tuck 12" rims in the fenders. 12" wide 4.5 backspace with 29x15x15 M/Ts
the 94 jeep rear axle is a real close close to A-body specs.
I have used the jeep axle in the D series trucks to get 3.73 & 4.10 gears tucking the 12 in the fenders. SB seems ok/BB not so much.
I will be getting a 98 with disc brakes and will burn off the coil spring stuff and add perches on 43" center next for a 76 truck.
I only wish I found this info when I had my 68 Dart
